With advanced technology that delivers consistent high performance in a multitude of applications, and with ten times the workload capability of desktop drives, WD Re is the workhorse of the WD's datacenter portfolio. WD Re is perfect for high-availability storage arrays that demand the most robust storage device available. High performance, capacity and reliability make WD Re ideal for data warehousing/mining and high-performance computing.
High capacity Nearline drive
Massive capacities up to 6 TB suit even the most demanding datacenter, enterprise server, or cloud storage needs. -
Designed for high-intensity applications
Designed to handle up to 550 TB per year - the highest workload capability of any 3.5-inch hard drive - delivering both performance and reliability to any datacenter environment. -
Designed for durability and reliability
With up to 2 million hours MTBF, this high performance drive delivers the highest level of reliability for 24x7x365 operation in the most demanding storage environments.
- WD RE WD2004FBYZ - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NoTouch ramp load technology, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T.
- 101.6 mm x 147 mm x 26.1 mm
- 640 g
- 5-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 640 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 200 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1H
- Power Consumption
- 7.4 Watt (read) , 7.4 Watt (write) , 8.1 Watt (active) , 5.9 Watt (idle)
- RoHS 2011/65/EU, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
