My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption.
Dependable
Trust My Passport Ultra to help protect your precious memories and confidential files -
Sleek design with high capacity
With extreme capacities in the palm of your hand, My Passport Ultra is an ideal companion for your laptop or compatible tablets. -
Ultra-fast transfer rates
The power of USB 3.0 lets you access and save files in blazing-fast speed. Best of all, no separate power supply is needed. -
You're in control
Configure, manage and diagnose your drive with WD Drive Utilities. Run drive diagnostics, erase and format your drive, register your drive and more.
- WD My Passport Ultra WDBMWV0020BTT - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Hardware encryption
- Power Source
- USB bus
- Enclosure Colour
- Titanium
- 82 mm x 20.9 mm x 110.5 mm
- 230 g
- Localisation
- Middle East, Africa, Europe
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 82 mm
- 20.9 mm
- 110.5 mm
- 230 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- WD Security, WD Drive Utilities, WD SmartWare Pro
- OS Required
- Apple MacOS, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable
- RoHS
- Enclosure Colour
- Titanium
- Localisation
- Limited warranty - 3 years
- 5 °C
- 35 °C
