The best-selling My Book external drive is an elegant, high-capacity storage solution for all the chapters of your digital life. My Book for Mac features visual, easy-to-use, automatic, continuous backup software and drive lock security protection. At last, beauty, brains, and simplicity together.
Smaller, sleeker, more streamlined design
They've made these award-winning drives even smaller, sleeker, and more elegant. As always, this book-like shape takes up minimal space on your desk and allows two or more My Book drives to nestle neatly together like volumes on a shelf. -
Designed for Mac
Formatted for Mac and compatible with Apple Time Machine, this drive is plug-and-play ready for Mac computer users. -
Drive lock
Gain peace of mind knowing that your data is protected from unauthorized access or theft with password protection and 256-bit hardware-based encryption. -
Illuminated capacity gauge
See at a glance how much space is available on your drive. -
USB 2.0 interface
The simple connection offers convenience and compatibility among multiple computers. -
Power miser
My Book external drives are designed to save energy. WD GreenPower Technology lowers internal drive power consumption by up to 30%, a sleep mode reduces power during idle times, and a power-saving feature turns the drive on and off with your computer.
- WD My Book for Mac WDBEKS0020HBK - hard drive - 2 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication, Apple Time Machine compatible, HFS+ formatted
- Power Source
- Included AC adapter
- 48 mm x 135 mm x 165 mm
- 1.18 kg
- Localisation
- Middle East, Africa, Europe
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 48 mm
- 135 mm
- 165 mm
- 1.18 kg
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Software Included
- WD Security, WD Drive Utilities
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable
- RoHS
- Localisation
- Limited warranty - 3 years
- 5 °C
- 35 °C
