WD Elements USB 2.0 external hard drive is an easy-to-use, reliable way to add more storage to your PC or Macintosh. Simply plug it in to a USB port and start saving or backing up your photos, music, video, and files. It's preformatted for immediate use so there's no software or CD to load. The compact, durable metal case provides extra data protection helping keep data safe from loss.
- WD Elements Desktop WDBAAU0020HBK - hard drive - 2 TB - USB 2.0
- Hard drive - external ( desktop )
- Capacity
- 2 TB
- Interface
- USB 2.0
- Data Transfer Rate
- 480 Mbps
- Power Source
- Included AC adapter
- 12.5 cm x 20.4 cm x 3.6 cm
- 1.02 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Capacity
- 2 TB
- Interface
- USB 2.0
- 12.5 cm
- 20.4 cm
- 3.6 cm
- 1.02 kg
Performance
- Interface Transfer Rate
- 480 Mbps
Expansion & Connectivity
- 1 x USB 2.0
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- OS Required
- Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
- Cables Included
- 1 x USB cable - external
- RoHS
- 5 °C
- 35 °C
