WD 16TB (2x8TB) My Book Pro 2bay Desktop NAS Thunderbolt USB3.0
Quicklinx: C1SBWS00 Mfr#: WDBDTB0160JSL-EESN
My Book desktop storage is optimized for the best possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to save and access files up to 3x faster than with USB 2.0. My Book offers complete backup options with WD SmartWare Pro software for local and cloud backup and Acronis True Image WD Edition software for system level backup. Gain peace of mind knowing that your data is protected from unauthorized access with password protection and hardware encryption. WD's Windows 8 app makes it easy to discover the digital media stored on your My Book drive with your Windows 8 computer. Your content is automatically displayed and organized so you can easily locate and enjoy your photos, videos and music. With this drive you get connectivity with the latest USB 3.0 devices as well as backward compatibility with USB 2.0 devices. With up to 6 TB capacity, there's plenty of room to store and protect your precious memories and important files. Use WD Security to set password protection and hardware encryption. Gain peace of mind knowing that your data is protected from unauthorized access.
  • Ultra-fast transfer rates
  • Complete backup for peace of mind
  • Keep your private stuff private
  • Works great with Windows 8
  • System-level backup
    Acronis True Image WD Edition is an integrated software suite that ensures security of all information on your PC. It can back up the entire disk drive or selected partitions, including your operating system, applications, settings and all of your data. You can also use the software to securely delete any confidential data you no longer need.
  • Automatic backup software
    WD SmartWare Pro automatic backup software works quietly in the background to help protect your data using minimal PC resources. Select automatic continuous backup to instantly create a second copy of your files. Or select the scheduled backup option to back up your files on your schedule and take control of your backup.
  • Local and cloud backup
    WD SmartWare Pro lets you choose. Back up your files to your My Book drive or back up your files to the cloud using your Dropbox account. You can also back up files from your Dropbox account to your My Book drive for extra protection.
  • Universal connectivity
  • Massive capacity
WD My Book Pro WDBDTB0160JSL - hard drive array
Hard drive array
Black and silver
Total Array Capacity
16 TB
USB 3.0, Thunderbolt 2
2 (installed) / 2 (max)
EMEA
Storage Controller
RAID RAID RAID 0, 1, JBOD
Hard Drive
2 x 8 TB HDD - hot-swap - Apple Time Machine compatible, HFS+ formatted, toolless
Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
AC 120/230 V - 50/60 Hz
10.86 cm x 21.61 cm x 14.78 cm
3.5 kg
3-year warranty
Hard drive array
Enclosure Colour
Black and silver
EMEA
Chassis
2
Supported Devices / Modules Qty
2
Storage
16 TB
HDD Array External Interface
CPU
Xeon
Storage Controller
RAID
Data Transfer Rate
435 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 8 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B , 2 x Thunderbolt 2
Security lock slot (cable lock sold separately), metal housing
1 x USB 3.0 cable , 1 x Thunderbolt cable - 1 m
Software Included
WD Drive Utilities
RoHS
External power adapter
10.86 cm
21.61 cm
14.78 cm
3.5 kg
Limited warranty - 3 years
35 °C
