Vision's SP-1600 loudspeakers are easier to install than any other speaker in its class, with superb sound quality and a robust chassis. They are powerful, professional, and acoustically optimized for the Vision range of amplifiers.
Lower bass response
A structurally rigid MDF chassis and a specially tuned bass reflex port have extended the bass response down, resulting in more natural music reproduction. -
Rugged grille
Refreshed industrial design makes the SP-1600 attractive and robust. The thick metal grille protects the drivers from physical interference. -
Tough finish
The textured paint finish withstands the rigors of the professional use. -
AV applications
AV presentation environments demand a wide dispersion so everyone in the audience can hear clearly, so the SP-1600 uses ferro-fluid cooled dome tweeters. -
Close-fit bracket
The slim profile brackets allow a very close fit to the walls of less than 20 mm.
- Vision SP-1600 - speakers
- Product Type
- Speakers
- System Components
- 2 speakers
- Speaker Type
- 2-way - passive
- Continuous Power
- 50 Watt
- Frequency Response
- 75 - 20000 Hz
- Nominal Impedance
- 8 Ohm
- Speaker System Details
- 2 x speaker 50 Watt - 75 - 20000 Hz - 8 Ohm
- White
- 15 cm x 16 cm x 24 cm
- 2-year warranty
- Product Type
- Speakers
- Enclosure Colour
- White
- Enclosure Material
- MDF
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - passive
- Continuous Power
- 50 Watt
- 75 - 20000 Hz
- Nominal Impedance
- 8 Ohm
- Recommended Placing
- Wall-mountable
- Speakers Included
- 2 x speaker - 2-way - 50 Watt - 75 - 20000 Hz - 8 Ohm - wall-mountable - wired
- Driver Details
- Speaker: woofer driver - 4" , Speaker: tweeter driver - 1"
- 15 cm
- 16 cm
- 24 cm
- Limited warranty - 2 years
