With a powerful 30 watt amplifier built in, the SP-1200P powered loudspeakers suit any audio-visual presentation environments such as classrooms and meeting rooms, bars and restaurants. They are simple to install and sound great!
Remote control
A full range of options are presented on the IR remote control, including bass and treble adjustment. -
Digital
The SP-1200P is assembled by a fully automated production line to ensure reliability, and uses a quality Yamaha class-D digital amplifier chip. -
Volume on front
A dial on the front of the 'master' loudspeaker - the one containing the amplifier - allows easy access to volume adjustment. A short push on the volume dial changes input, and a long push turns the power on and off. -
External power supply
An external power supply helps overcome a distant mains power source, and allows all input and output signals to pass through the phoenix connector block, making de-installation very simple. -
Enhanced sound
A powerful amplifier coupled with a rigid chassis results in fantastic sound. -
When power is connected the SP-1200P automatically comes on and remembers the previous input and volume setting. Restoring power brings the loudspeakers back to life automatically. -
2-way drivers
Built to last, the SP-1200P feature a proven two-way driver design with a professional passive cross-over.
- Vision SP-1200P - speakers
- Product Type
- Speakers
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Nominal Output Power (Total)
- 30 Watt
- Frequency Response
- 80 - 16000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x speaker 15 Watt - 80 - 16000 Hz - 4 Ohm
- White
- Power
- AC 230V
- 14.5 cm x 15 cm x 22 cm
- 2-year warranty
- Product Type
- Speakers
- Enclosure Colour
- White
- Enclosure Material
- MDF
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Audio System Continuous Power (Total)
- 30 Watt
- 80 - 16000 Hz
- Sensitivity
- 85 dB
- Amplifier
- Integrated
- Recommended Placing
- Wall-mountable
- Controls
- Volume
- Speakers Included
- 2 x speaker - 2-way - 15 Watt - 80 - 16000 Hz - 4 Ohm - wired
- Driver Details
- Speaker: woofer driver - 4" , Speaker: tweeter driver - 1.5" - silk
- Connector Type
- Audio line-in (RCA x 2) , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor, wall mounting brackets, speaker cable, IR remote control
- Power Source
- AC power adapter
- Voltage Required
- AC 230V
- 14.5 cm
- 15 cm
- 22 cm
- Limited warranty - 2 years
