The ViewSonic VX2209 is a 22'' Full HD LED display with premium glossy-finish, slim bezel design and stylish glass base, featuring a 1920 x 1080 resolution, 20M: 1 DCR and a 5ms response time to deliver crisp color performance. Equipped with DVI and VGA inputs, it can easily connect to a PC or laptop for office work, internet browsing or home entertainment. With an energy-efficient LED backlight and ECO mode, the VX2209 is an environmentally friendly display choice. Furthermore, the VX2209 provides sRGB and Color Adjust functions, offering image reproduction quality that closely matches the original image source.
Slim bezel with premium glass base
VX2209 adopts a slim bezel and premium glass base design that is available in black. These features increase the screen surface area, giving the VX2209 a sleek, fashionable look that stands out in any setting. -
Full HD 1080p for superior pixel performance
The ViewSonic VX2209 features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of playtime, and is perfectly compatible with multi-window viewing without toggling. -
Planet-friendly mercury-free LED backlighting
LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy when compared to conventional displays. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space. -
Eco-mode conserves more energy
ViewSonic's proprietary Eco-mode feature is built into all LED displays, offering options to select "Optimize" or "Conserve" settings that save power. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the display's lamp life. With Eco-mode, both lamp replacement and energy expenditures are reduced. -
20M: 1 MEGA dynamic contrast ratio
Dynamic contrast ratio detects the brightness of an image, and automatically adjusts the backlight to maximize the monitor's color range and contrast. Dynamic contrast ratio technology enables the accurate reproduction of images, producing vibrant and rich visual effects. -
Reviving color with sRGB color correction technology
Accurate and consistent color performance is essential for professionals in graphic design, video editing, and other professional environments. With built-in sRGB color correction technologies, the VX2209 reproduces 100% sRGB rich color performance and captures images in their original and true colors.
- ViewSonic VX2209 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 50.11 cm x 21.5 cm x 35.58 cm
- 3.07 kg
- RoHS, WEEE, CU-EAC
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio, slim bezel design, Mercury free
- 50.11 cm x 21.5 cm x 35.58 cm - with stand
- 3.07 kg
Mechanical
- Tilt
- Tilt Angle
- -3/+20
- Cables Included
- 1 x VGA cable
- Backlight Life
- 30,000 hours
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Dimensions & Weight Details
- Without stand - width: 50.11 cm - depth: 3.357 cm - height: 29.78 cm - weight: 2.46 kg , With stand - width: 50.11 cm - depth: 21.5 cm - height: 35.58 cm - weight: 3.07 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
