The ViewSonic VG2433-LED is a 23.6" display ideal for demanding business professionals. With a native 1920 x 1080 resolution, the VG2433-LED delivers vibrant images and crisp text. Users will also find comfort in the fully ergonomic height adjust, swivel, and tilt features. Equipped with a VESA-mountable design, the display can be mounted on a wall or any VESA-compliant monitor stand. The VG2433-LED also saves up to 50% in energy usage with its efficient LED backlight.
Ergonomic design for comfortable working environments
Users can reduce eyestrain and physical fatigue by adjusting the monitor to create their own most comfortable work environment. The VG2433-LED is designed to maximize comfort and productivity with advanced ergonomic technology. -
Full HD resolution for superb pixel performance
Experience the most amazing clarity and detail for any of your computer applications, Microsoft Office Suite operations, or for enjoying the latest multimedia entertainment. The VG2433-LED features Full HD 1920 x 1080 resolution to ensure excellent pixel-by-pixel image performance. Additionally, this 16:9 large screen allows the user to operate multiple windows side by side, thus facilitating a more efficient work environment. -
MEGA dynamic contrast ratio delivers sharp and crisp images
The superior dynamic contrast ratio of 20,000,000:1 delivers a broader range of grayscale, with darker blacks and brighter whites, to ensure all images displayed are rich and detailed. An extremely fast 5 ms response time results in crisp and clear video performance. Experience digital broadcast-quality, full-motion video with razor-sharp images that never blur. -
Eco mode saves energy and lowers total cost of ownership
ViewSonic's proprietary eco mode function is built into all LED displays to provide setting options to "optimize" (75%) and "conserve" (50%). Both modes reduce display brightness and conserve up to 40% more energy. Eco Mode adjusts brightness and improves visibility, especially in low ambient light, to reduce eye fatigue and prolong display lamp lifetime. With eco mode, replacement expenditures are reduced while practicing eco-friendliness. -
sRGB delivers the most accurate color performance
Accurate and consistent color performance is essential for professionals in graphic design, video editing, and other multimedia related environments. With built-in sRGB color correction technology, the VG2433-LED reproduces images in their original and authentic colors.
- ViewSonic VG2433-LED - LED monitor - 23.6"
- LED-backlit LCD monitor - 23.6"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- FullHD 1920 x 1080
- Brightness
- 300 cd/m2
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA
- Height adjustable, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 56.6 cm x 20.43 cm x 38.24 cm - with stand
- 4.66 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified , EPEAT Silver
- 3 years warranty
- Display Type
- Diagonal Size
- 23.6"
- Viewable Size
- 23.6"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Brightness
- 300 cd/m2
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
- Black
- 4.66 kg
- VGA , DVI-D
Mechanical
- Height, pivot (rotation), swivel, tilt
- Tilt Angle
- -5/+25
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 30,000 hours
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 22 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- With stand - width: 56.6 cm - depth: 20.43 cm - height: 38.24 cm - weight: 4.66 kg , Without stand - width: 56.6 cm - depth: 5.1 cm - height: 34.32 cm - weight: 3.22 kg
- EPEAT Compliant
- EPEAT Silver
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
