ViewSonic VG2239M-LED 22 MM DVI-D/PORT
Quicklinx: 88V4WS00 Mfr#: VG2239M-LED
The VG2239m series widescreen monitor is one of two members of ViewSonic's VG39 family. Its 22" display with a native 1920 x 1080 resolution is big enough to replace dual monitor setups. What makes it even more appealing is the LED backlight for up to 50% energy savings. Monitor is also fully ergonomic with 90º pivot, height adjust, swivel and tilt. The slim bezel design coupled with hidden stereo speakers make the VG2239m a space saver.
The VG2239m-LED features DisplayPort, DVI-D digital, and a VGA analog input. You can connect multiple sources at the same time and then toggle between them by selecting the input source through the On-Screen-Display (OSD). You can also connect one of your computer's USB ports to the monitor's USB uplink input which then multiplies the USB ports to two. This way, you can connect your keyboard / mouse or other peripherals to your monitor directly and save yourself from the hassle of reaching for your computer's USB ports.
  • High performance DisplayPort connectivity
    The VG2239m-LED is equipped with DisplayPort digital interface, which transmits both audio and video signals through a single connection to deliver ultimate versatility and performance. DisplayPort supports all kinds of multimedia devices for convenience in video production, graphic design and more.
  • Efficiency and comfort
    Ergonomics is defined as the profession of designing tools and work environments to best accommodate human performance and behavior. The VG2239m-LED is one of the great examples of an ergonomically designed tool. Based on your height, chair and desk conditions, you can adjust it up and down for 5.3", swivel it 360°, or tilt it 20°, whatever makes you more comfortable.
  • Diverse connectivity
  • Mega dynamic contrast ratio
    One of the great features of VG2239m-LED is its ability to dim the backlight completely for pure darkness during dark scenes, such as a night shot in a movie. Contrast ratios refer to the ratio of the brightest color to the darkest color. With traditional CCFL backlit displays, contrast ratios are limited to the fluorescent lamp's ability to dim, in order to reproduce darkness. However, with the LED backlight, each LED has the ability to completely shut-off allowing for a near infinite ratio of black to white contrast. The end result is true blacks that result in greater overall image quality.
  • Full HD 1080p resolution
    The VG2239m-LED features a 22" widescreen with 1920 x 1080 resolution is capable of displaying a native Full HD 1080p image. Today, devices that can display Full HD content output are getting more and more common. However, without a native Full HD display, you will not be able to experience the picture clarity and the details of the 1080p content you view.
  • Eco-mode for up to 50% energy savings
    ViewSonic's proprietary Eco-mode function comes standard with the VG2239m-LED. When you don't need all of the powerful features the VG2239m-LED has to offer, you have the option to reduce the monitor's brightness, save energy, save the planet and prolong the lamp life.
ViewSonic VG2239m-LED - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
51.24 cm x 23.96 cm x 41.8 cm
4.7 kg
Americas
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, UL, cUL, GS, ICES-003, CB, EMC, DOC, RoHS, WEEE, REACH, UkrSEPRO, ERP, EAC, SVHC, Mexico CoC
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, H-size, aspect control
sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
51.24 cm x 23.96 cm x 41.8 cm - with stand
4.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in (mini-jack) , DisplayPort , 2 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B) , Headphones (mini-jack)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
90
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Backlight Life
40,000 hours
Americas
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
22 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 51.24 cm - depth: 5.64 cm - height: 30.44 cm - weight: 3.2 kg , With stand - width: 51.24 cm - depth: 23.96 cm - height: 41.8 cm - weight: 4.7 kg
Shipping Width
58.1 cm
Shipping Depth
18.7 cm
Shipping Height
48.3 cm
Shipping Weight
6.7 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 90% (non-condensing)
