ViewSonic VA2855SMH 28" 1920x1080 6.5ms VGA HDMI LED Monitor with Speakers
VIEWSONIC NOW OFFERS ONE EXTRA YEAR WARRANTY!
Quicklinx: 9Y1BWS00 Mfr#: VA2855SMH
ViewSonic's VA2855Smh is a 28'' LED multimedia display that delivers great color performance. It features the exclusive SuperClear Pro image technology for superior wide-angle viewing, 3,000:1 static contrast ratio and true 8-bit color for amazingly consistent, true-to-life color performance. Full HD 1080p resolution and dual stereo speakers deliver sharp and detailed images with crystal-clear sound for both home entertainment and office use. ViewSonic's Flicker-free and Blue Light Filter eye-care technologies also reduce eye fatigue and provide a more comfortable home or office environment. In addition, ViewMode technology provides users to choose the appropriate color performance based on different scenarios, including gaming, movie watching, photo viewing, Web browsing or reading e-docs. Integrated HDMI and D-Sub inputs offer flexible connection with PCs, notebooks and other HD devices.
  • Experience better viewing on a large 28" screen
    The ViewSonic VA2855Smh is a 28'' LED display ideal for both home entertainment and office work. The enlarged 28'' viewing area increases work efficiency and productivity by making it easy to view large spreadsheets or two side-by-side applications.
  • SuperClear Pro technology for rich Colors, better gradients, and sharper images
    SuperClear Pro technology provides true 8-bit color performance that displays millions of undistorted colors, a superior static contrast ratio of 3000:1 for enhanced clarity of detail in dark and bright images, and wide-angle color consistency for uncompromising image quality at virtually any angle.
  • Full HD 1080p for Superior Pixel Performance
    The VA2855Smh features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. Experience amazing clarity and detail whether it be while working, gaming, or enjoying multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of viewing, and is perfectly compatible with multi-window viewing without toggling.
  • Better color depth with 3000:1 static contrast ratio
    An ultra-high static contrast ratio of 3000:1 offers a wide range of grayscale to show deep, rich colors with more visible details in shadows and highlights. The VA2855SMH can display vivid and realistic images for photo editing, watching movies, or any multimedia application.
  • ViewSonic Flicker-Free viewing for improved eye comfort
    ViewSonic Flicker-Free displays deliver on the promise of more comfortable viewing. ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power - eliminating screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer - without causing eye fatigue.
  • Blue Light Filter for more comfortable viewing
    Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling long viewing times and increased eye comfort for work and multimedia applications.
  • HDMI for Full HD content connectivity
    ViewSonic VA2855Smh is equipped with HDMI input for high definition connectivity to set-top box, Blu-ray disc and Full HD camcorder devices, for trouble-free application in graphic design and video production environments.
  • Dual Integrated Stereo Speakers
    The ViewSonic VA2855Smh is featured with two integrated stereo speakers for enhanced multimedia performance and a crystal-clear stereo sound.
  • Planet-friendly mercury-free LED backlighting
    LED backlighting enhances display performance, delivering an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy.
ViewSonic VA2855Smh - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
65.97 cm x 24.97 cm x 45.26 cm
5.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, UL, cUL, WHQL, CB, RoHS, WEEE, REACH, NRCAN
Display Type
Energy Class
Class B
50 kWh
Diagonal Size
28"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Eco-Mode, Flicker Free technology, blue light reduction, SuperClear Pro, a-Si technology
65.97 cm x 24.97 cm x 45.26 cm - with stand
5.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA (HD-15) , HDMI , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Backlight Life
40,000 hours
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
34 W
Power Consumption (Typical)
32 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 65.97 cm - depth: 24.97 cm - height: 45.26 cm - weight: 5.3 kg , Without stand - width: 65.97 cm - depth: 4.93 cm - height: 39.1 cm - weight: 4.7 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
10 - 90% (non-condensing)
