ViewSonic's VA2855Smh is a 28'' LED multimedia display that delivers great color performance. It features the exclusive SuperClear Pro image technology for superior wide-angle viewing, 3,000:1 static contrast ratio and true 8-bit color for amazingly consistent, true-to-life color performance. Full HD 1080p resolution and dual stereo speakers deliver sharp and detailed images with crystal-clear sound for both home entertainment and office use. ViewSonic's Flicker-free and Blue Light Filter eye-care technologies also reduce eye fatigue and provide a more comfortable home or office environment. In addition, ViewMode technology provides users to choose the appropriate color performance based on different scenarios, including gaming, movie watching, photo viewing, Web browsing or reading e-docs. Integrated HDMI and D-Sub inputs offer flexible connection with PCs, notebooks and other HD devices.
Experience better viewing on a large 28" screen
The ViewSonic VA2855Smh is a 28'' LED display ideal for both home entertainment and office work. The enlarged 28'' viewing area increases work efficiency and productivity by making it easy to view large spreadsheets or two side-by-side applications. -
SuperClear Pro technology for rich Colors, better gradients, and sharper images
SuperClear Pro technology provides true 8-bit color performance that displays millions of undistorted colors, a superior static contrast ratio of 3000:1 for enhanced clarity of detail in dark and bright images, and wide-angle color consistency for uncompromising image quality at virtually any angle. -
Full HD 1080p for Superior Pixel Performance
The VA2855Smh features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. Experience amazing clarity and detail whether it be while working, gaming, or enjoying multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of viewing, and is perfectly compatible with multi-window viewing without toggling. -
Better color depth with 3000:1 static contrast ratio
An ultra-high static contrast ratio of 3000:1 offers a wide range of grayscale to show deep, rich colors with more visible details in shadows and highlights. The VA2855SMH can display vivid and realistic images for photo editing, watching movies, or any multimedia application. -
ViewSonic Flicker-Free viewing for improved eye comfort
ViewSonic Flicker-Free displays deliver on the promise of more comfortable viewing. ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power - eliminating screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer - without causing eye fatigue. -
Blue Light Filter for more comfortable viewing
Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling long viewing times and increased eye comfort for work and multimedia applications. -
HDMI for Full HD content connectivity
ViewSonic VA2855Smh is equipped with HDMI input for high definition connectivity to set-top box, Blu-ray disc and Full HD camcorder devices, for trouble-free application in graphic design and video production environments. -
Dual Integrated Stereo Speakers
The ViewSonic VA2855Smh is featured with two integrated stereo speakers for enhanced multimedia performance and a crystal-clear stereo sound. -
Planet-friendly mercury-free LED backlighting
LED backlighting enhances display performance, delivering an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy.
- ViewSonic VA2855Smh - LED monitor - Full HD (1080p) - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 65.97 cm x 24.97 cm x 45.26 cm
- 5.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- FCC Class B certified, UL, cUL, WHQL, CB, RoHS, WEEE, REACH, NRCAN
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 28"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Eco-Mode, Flicker Free technology, blue light reduction, SuperClear Pro, a-Si technology
- 65.97 cm x 24.97 cm x 45.26 cm - with stand
- 5.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA (HD-15) , HDMI , Audio line-in , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 40,000 hours
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- 34 W
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 65.97 cm - depth: 24.97 cm - height: 45.26 cm - weight: 5.3 kg , Without stand - width: 65.97 cm - depth: 4.93 cm - height: 39.1 cm - weight: 4.7 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
