ViewSonic's VA2248-LED features an LED backlight 22" thin bezel widescreen monitor. Environmentally friendly mercury-free VA2248-LED offers Full HD 1920 x 1080 resolution, 10,000,000:1 MEGA dynamic contrast ratio, DVI and VGA inputs, 5 ms response time, VESA mountable glossy finish design. The aspect ratio adjustment feature automatically senses the input single and will not stretch a 4:3 signal but instead will position the image in the middle of the screen with side bars.
- ViewSonic VA2248-LED - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- 1920 x 1080
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Screen Coating
- Anti-glare, hard coating
- 52.8 cm x 22.8 cm x 40 cm - with stand
- 3.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified , EPEAT Silver
- C-Tick, BSMI, NEMKO, CB, PSB, RoHS, WEEE, GOST-R, REACH, TCO Displays 5.1, ErP Ready, UkrSEPRO
- 3 years warranty
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- 1920 x 1080
- Brightness
- 250 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Aspect control
- HDCP, Eco-Mode
- Image Colour Disclaimer
- The image of the product displayed may be of a different colour
- 3.6 kg
- VGA , DVI-D
Mechanical
- Flat Panel Mount Interface
- 100 x 100 mm
- Wall mountable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 23 Watt
- EPEAT Compliant
- EPEAT Silver
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 90 day warranty and is in good working order. You can find out the exact details about each product using the key below.
| Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
7HLM 008978 Condition: Item has been used. Tatty box. |
£45.24 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
