ViewSonic's 50cm/20" VA2014w LCD brings value to big, widescreen displays.
This display doesn't compromise on features with 1600 x 900 resolution for brilliant HD images. This stylish 50cm/20-inch LCD delivers extreme clarity, amazing color with 20,000:1 dynamic contrast ratio and fast ClearMotiv 5ms video response. Benefit from greater productivity with the ability to view two full size documents side-by-side or work in multiple applications simultaneously on the widescreen display. Eco-mode conserves power and can extend backlight life. VA2014w fits seamlessly into any office decor.
- ViewSonic VA2014w - LCD monitor - 20"
- LCD monitor - 20"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 20000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, hard coating
- Black
- 48.1 cm x 20 cm x 36.9 cm - with stand
- 4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, C-Tick, BSMI, cUL, NOM, SASO, CB, CCC, TUV Ergo, PSB, IRAM, RoHS, KCC, WEEE, GOST-R
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 20"
- Viewable Size
- 20.0"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, sharpness, colour temperature, H-size, aspect control
- ClearMotiv, Eco-Mode, 4:3 in Wide
- Black
- 4 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- 25
- Flat Panel Mount Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Backlight Life
- 50,000 hours
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 25 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- With stand - 48.1 cm x 20 cm x 36.9 cm x 4 kg , Without stand - 48.1 cm x 6.4 cm x 28.8 cm
- 5 °C
- 35 °C
- 20 - 80%
