ViewSonic TD2420 24" 1920x1080 5ms VGA DVI-D HDMI Multi-Touch LED Monitor
Quicklinx: 91Q1WS00 Mfr#: TD2420
The ViewSonic TD2420 is the perfect solution for both commercial and consumer touch screen applications. With an intuitive multi-touch LED display, interactive stylus, and full HD resolution, the TD2420 delivers a versatile touch solution for use as a POS display, information kiosk, or in hospital and classroom environments. With Dual Point Optical technology, the TD2420 provides a fun and interactive experience to engage users. Equipped with 1920 x 1080 Full HD resolution, and 20,000,000:1 MEGA Dynamic Contrast Ratio, the ViewSonic TD2420 delivers extremely sharp and crisp images. As a complete multimedia package, the display also includes a pair of integrated 2-watt speakers with SRS Premium Sound. HDMI, VGA, and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional convenience for use as a wall-mounted display. The versatile TD2420 is the one-stop solution for your multi-touch display needs.
  • Dual point optical touch
    Dual point optical touch utilizes two or more image sensors that are usually placed around the edges of a display. These sensors allow the touch surface to recognize two contact points simultaneously, and provide users with direct interaction by allowing two-finger gestures such as zoom in/out, rotations, and two-finger taps. Because of optical touch's scalability, versatility, and affordability, it is becoming a popular technology for use on large format displays.
  • LED monitor
    The term "LED monitor" generally refers to a monitor with a LCD panel and a LED backlight. A typical LCD monitor uses cold cathode fluorescent lamps (CCFL) as a light source to illuminate the LCD panel. In an LED backlit monitor, white LEDs (Light Emitting Diodes) are used as the light source.
  • One-stop solution for multi-touch monitor needs
    TD2420's multi-touch interface and Full HD resolution makes it an ideal touch solution for both commercial and consumer applications. It gives commercial users the capability to create a direct and interactive user experience for their customers. Full HD resolution and high Dynamic Contrast Ratio delivers ultra image quality and color accuracy. Scratch-resistant surface hardness ensures the TD2420 can withstand heavy usage in a high traffic environment while maintaining a high quality touch experience.
  • Eco-mode for up to 40% energy savings
    ViewSonic's proprietary eco-mode function comes standard with the TD2420. When you don't need all of the powerful features that the TD2420 has to offer, you have the option to reduce the monitor's brightness, save energy, save the planet and prolong the lamp life. Especially under low ambient light conditions, adjusting the brightness will improve visibility by reducing eye fatigue. Reducing brightness will also prolong the monitor's lamp life, improving your return on investment.
  • Full HD 1080p resolution
    The TD2420 features a 24" widescreen with 1920 x 1080 resolution that is capable of displaying a native Full HD 1080p image. Devices that can display Full HD content output are getting more and more common. However, without a native Full HD display, you will not be able to experience the picture clarity and the details of the 1080p content you view.
  • Save cash and save the planet
    With its mercury-free backlight and low energy consumption, the ENERGY STAR certified TD2420 is not only environmentally friendly, but it's also friendly on your electricity bill. The savings of LED can add up to thousands of dollars saved for large install bases, such as big corporate buildings or schools.
ViewSonic TD2420 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Class
Class B
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
23 W
Touch-screen
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
210 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
55.59 cm x 17.48 cm x 42.19 cm
3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, KC, ERP
3-year warranty (Austria, Germany, Switzerland - 3 years)
Display Type
Energy Class
Class B
33 kWh
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
16:9
Native Resolution
Brightness
210 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
7H Hard Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
OptiSync, HDCP, Eco-Mode, SRS Premium Sound, Mega Dynamic Contrast Ratio
55.59 cm x 17.48 cm x 42.19 cm - with stand
3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Optical
VGA , DVI-D (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Stand, stylus
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
Supported Windows 7 Features
Windows Touch
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
23 W
Power Consumption (Typical)
25 Watt
Included Software
ViewSonic Wizard
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.59 cm - depth: 17.48 cm - height: 42.19 cm - weight: 3 kg , Without stand - width: 55.59 cm - depth: 5.61 cm - height: 34.68 cm - weight: 2.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Regional Warranty Exceptions
20 - 90% (non-condensing)
