BrilliantColor technology
Latest BrilliantColor technology delivers stunning all-digital clarity with life-like color, sharp graphics and outstanding video. The advanced 7-segment color wheel enhances the yellow color performance that is key to accurate and vivid color reproduction. -
Bright in virtually any setting with 2,000 lumens
Crisp 2,000 lumen output makes this the perfect choice for family room or home theater -
Closed captioning
Integrated closed captioning decoder for the hearing impaired -
Control capabilities
Features full RS232 control for seamless integration into your automation system -
Full 1080p HD resolution
Enjoy the finest quality in high-definition movies, video and TV -
Go green and save
Use the Eco-mode to achieve lower power consumption, reduce overall noise and extend lamp life -
Pixelworks high performance PW980 video processor
With full 10-bit color processing, detail enhancement technology and motion adaptive de-interlacer for crisper, sharper images -
Stay connected
Supports multiple video timing formats from SD (NTSC, PAL & SECAM) to HD 1080p -
Ultimate display source flexibility
Two HDMI 1.3 inputs with HDCP compliance and component video input provide full connectivity in a customized home theater installation
- ViewSonic Pro8200 - DLP projector - black
- DLP projector - 1080p
- Black
- Built-in Devices
- Stereo speakers
- Brightness
- 2000 lumens
- Contrast Ratio
- 3000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 360 Watt
- 33.3 cm x 26.4 cm x 11 cm
- 3.9 kg
- Built-in Devices
- Stereo speakers
- Enclosure Colour
- Black
Projector
- Brightness
- 2000 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 76 cm - 760 cm
- Projection Distance
- 0.9 m - 10 m
- Throw Ratio
- 1.4 - 2.14:1
- Resolution
- 16:9
- Max Sync Rate (V x H)
- 85 Hz x 100 kHz
- Bulb type
- 230 Watt
- Bulb life cycle
- Controls & Adjustments
- Mute, brightness, contrast, H/V position, colour balance, gamma correction, input select, keystone correction, noise reduction, aspect control
- Eco-Mode technology, Closed Caption, High-bandwidth Digital Content Protection System (HDCP), 7-segment colour wheel, BrilliantColor
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
Input Device
- Movement Detection Technology
- Laser
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B , 1 x microphone - mini-phone 3.5 mm
- Included Accessories
- Lens cover, remote control
- Cables Included
- 1 x VGA cable , 1 x HDMI cable
- Security Features
- Password protection
- FCC Class B certified, UL, C-Tick, cUL, NOM, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, ICES-004, UkrSEPRO
- Voltage Required
- 360 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- Software Included
- ViewSonic Wizard
- 33.3 cm
- 26.4 cm
- 11 cm
- 3.9 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 27 dB
