The ViewSonic PJD6544w is an advanced networkable WXGA DLP projector that delivers bright widescreen images in any setting. Equipped with Crestron LAN controller, the PJD6544w makes it easy for IT admin to remotely control and manage multiple projectors from their workstations. Built with BrilliantColor technology, this projector produces vibrant colors, while 3500 ANSI lumens and 15000:1 contrast ratio deliver stunning, razor-sharp images. Certified with AMX Device Discovery, the PJD6544w easily integrates into any size campus or enterprise. In addition, the PJD6544w is packed with advanced features including wired and wireless LAN display, USB display, a mobile app for smart phones and tablets, capability for PC-less presentations, 3D Blu-ray ready HDMI, and integrated speakers. The PJD6544w is the perfect projector for both classroom and corporate settings where a powerful widescreen projection is necessary.
Bright in classroom and conference room
Packed with 3500 lumens and a high contrast ratio of 15,000:1 (with DynamicEco), the PJD6544w is guaranteed to shine bright - even in large classrooms and meeting rooms. -
Widescreen brilliance
With a native 1280 x 800 (WXGA) resolution, the PJD6544w wide format projector offers a tremendous degree of flexibility and compatibility. Whether connecting a widescreen notebook in the conference room, or watching 720p/1080p HD content in the classroom, a distortion-free image with matching aspect ratio is guaranteed. -
Wireless and wired LAN display
With its advanced networking capability, the projector can project images via wireless, or wired, LAN. The LAN display offers a quad split screen for simultaneously projecting content from up to 4 PCs, with the ability to broadcast from up to 8 projectors. -
Jump start your presentation without waiting for the PC to boot up. With a PC-less presentation feature, you can display MS Office documents, PDFs, videos or images directly from a USB flash drive. -
Plug and Play USB display
Project your presentations using a quick and simple Plug-and-Play USB connection without running a bulky VGA cable. Plug and Play also features automatic resolution detection for the best imaging experience. -
HDMI delivers the high picture and sound quality without degradation. Equipped with the HDMI, ViewSonic's PJD6544w projector can display 3D images directly from 3D Blu-ray players - perfect for connecting to any HDMI-enabled devices such as PCs, laptops, tablets, and media players. -
Superior color performance
BrilliantColor technology provides multi-color processing to produce stunning, vibrant colors. Unlike other technologies that use just 3 primary colors to produce the image (such as LCD), the PJD6544w uses up to 5 separate colors. The sophisticated 5-segment color wheel enhances the yellow color performance that is key to accurate and vivid color reproduction.
- ViewSonic PJD6544w - DLP projector - 3D - LAN
- DLP projector - 720p
- 3D Capable
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- 1200 x 800
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 305 Watt
- 29.4 cm x 21.9 cm x 11.3 cm
- 2.1 kg
- 3D Capable
Projector
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 71 cm - 762 cm
- Projection Distance
- 1.2 m - 11.8 m
- Throw Ratio
- 1.47 - 1.83:1
- Resolution
- WXGA - 1200 x 800 (native) / 1600 x 1200 (resized)
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- 5-segment colour wheel, BrilliantColor, USB host function, DLP 3D Ready, Crestron RoomView, AMX Device Discovery, DynamicEco Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone mono 3.5 mm , 1 x microphone - mini-phone mono 3.5 mm , 1 x audio line-out - mini-phone mono 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x USB - mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- FCC Class B certified, UL, C-Tick, cUL, NOM, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, REACH, UkrSEPRO, KC, ERP
- Voltage Required
- 305 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 29.4 cm
- 21.9 cm
- 11.3 cm
- 2.1 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 32 dB
