The ViewSonic PJD6543w is a networkable WXGA DLP projector that delivers brilliant images in a widescreen format. Ideal for classroom and corporate LAN environments, the PJD6543w is equipped with Crestron LAN controller - making it easy for IT admin to remotely control and manage multiple projectors from their workstations. Certified with AMX device discovery, the PJD6543w easily integrates into any size campus or enterprise. Built with BrilliantColor technology, this projector produces vibrant colors, while 3000 ANSI lumens and 15000:1 contrast ratio deliver stunning, razor-sharp images. With the latest HDMI, the PJD6543w can display 3D images from Blu-ray players. A filter-less design and DynamicEco technology reduces brightness by 70% when not in use - providing for virtually zero maintenance and a longer product life. The PJD6543w is the perfect projector for both classroom and corporate settings with widescreen projection needs.
3000 lumens shine in virtually any setting
Uses fewer watts per lumen than other comparable projectors. And with 15000:1 contrast, the PJD5234 is the bright choice for business and education. -
Widescreen WXGA resolution perfect for 720p HD viewing
A wide format projector supporting a native 1280 x 800 (WXGA) resolution offers a tremendous degree of flexibility and compatibility. Whether you are connecting your widescreen notebook in a conference room, or showing the latest HD 720p/1080p content in a classroom, you are guaranteed a distortion-free image with a matching aspect ratio. -
DLP technology
Advanced DLP (Digital Light Processing) technology allows you to experience crystal clear, razor-sharp and lifelike images with the same DLP technology used in Hollywood. For fast action, the response time is 1,000 times faster than similar LCD-based projectors. And with no air filters to clean or change, the latest generation of DLP-based projectors from ViewSonic is among the lowest TCO (Total Cost of Ownership) in the industry. -
The ViewSonic PJD6543w projector with BrilliantColor technology features multi-color processing to produce stunning, vibrant colors. Unlike other technologies that use just 3 primary colors to produce the image, the PJD6543w uses up to 6 separate colors. The sophisticated 6-segment color wheel enhances the yellow color performance that is key to accurate and vivid color reproduction. With multi-color processing, colors are richer and more vibrant with exquisite and precise detail. -
LAN control & monitoring with Crestron& AMX
Take advantage of network control and monitoring capabilities to help IT personnel manage projectors efficiently and effectively - from having full remote access and control to saving valuable time and money. The ViewSonicPJD6543w offers seamless integration and full support for Crestron and AMX control systems. -
3D Blu-ray ready with HDMI
With the latest HDMI, the ViewSonic PJD6543w projector can now display 3D images directly from 3D Blu-ray players. The PJD6543w is designed to provide an amazing 3D visual experience for classroom, office, and even home environments. -
DynamicEco technology for total control of audience's focus
With the DynamicEco button on the remote control, take command of presentations by dimming the screen brightness by 70%. This feature allows presenters to easily shift the audience's focus when the projector is not in use. When idle, the projector will auto-activate DynamicEco as well. When DynamicEco is activated, the lamp's power consumption is significantly reduced - a great energy-saving design for low total cost of ownership (TCO). -
Virtually maintenance-free with filter-less design
The ViewSonic PJD6543w projector features a filter-less design. Unlike LCD projectors that require users to clean, or sometimes replace, filters every 100 to 300 hours of operation, the ViewSonic PJD6543w projector's filter-less design eliminates filter cleaning or filter replacement. This provides virtually zero maintenance, saves you significant dollars and labor over the projector's lifespan, and lowers your total cost of ownership (TCO). -
Long-lasting reliable picture quality & superior color performance
ViewSonic DLP projectors provide reliable picture quality you can trust and superior color performance you can count on, after thousands of hours of usage. Built on DLP technology, ViewSonic's PJD6543w projector virtually eliminates image degradation known as color decay - a yellow/faded tint that LCD projectors may develop after extended use. Even after years of use, the PJD6543w will continue to produce a stunning, sharp image that lasts. -
PC 3D-ready/120Hz refresh rate powered DLP Link technology
With support for DLP Link technology, you'll have amazing 3D capabilities at your disposal. All that's required to unlock 3D capabilities on the ViewSonic PJD6543w 3D-ready projector is ViewSonic's PGD-series 3D active shutter glasses, 3D content, and a 3D-enabled video card. Unleash a vivid 3D experience with the ViewSonic PJD6543w projector today. -
Small & light for easy portability
Measuring only 3.3 inches high and weighing only 4.6 pounds, ViewSonic's PJD6543w is light and compact, making it the perfect portable projector for mobile sales and business travelers.
- ViewSonic PJD6543w - DLP projector - 3D - black
- DLP projector - 720p
- 3D Capable
- Black
- Microdisplay
- DMD Chip
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 240 Watt
- 26.8 cm x 22.1 cm x 8.44 cm
- 2.1 kg
- 3D Capable
- Enclosure Colour
- Black
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 71 cm - 762 cm
- Projection Distance
- 0.9 m - 9.7 m
- Throw Ratio
- 1.5 - 1.65:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, 6-segment colour wheel, BrilliantColor, DLP 3D Ready, Crestron RoomView, AMX Device Discovery, Crestron e-Control, Filter Free, DynamicEco Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- Speakers
- 2 x right / left channel
- 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B , 1 x network - RJ-45 (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- UL, TUV GS, C-Tick, cUL, ICES-003, NOM, SASO, CB, CCC, PSB, FCC, RoHS, WEEE, UL-AR, GOST-R, UkrSEPRO, KC, CECP
- Voltage Required
- 240 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 26.8 cm
- 22.1 cm
- 8.44 cm
- 2.1 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 29 dB
