ViewSonic PJD5250 XGA 3100 Lumens Projector
Quicklinx: BCYQWS00 Mfr#: PJD5250
The ViewSonic LightStream Projector PJD5250 is the ultimate price-performance projector, integrating elegant style and intuitive design, VGA connectivity and best in class color performance thanks to exclusive SuperColor technology. The PJD5250 is equipped with 3,100 lumens brightness, a 6-segment color wheel, high resolution 4:3 (XGA 1024 x 768) and 18,000:1 contrast ratio for great image quality even in spaces with high ambient light. Eco mode further reduces power consumption by up to 70% and extends the lamp life up to 10,000 hours.
  • Premium curved design with intuitive keypad
    With its dot texture finish and curved edges, this LightStream Projector stands out from the competition. A tactile keypad provides ease of use with raised and concave buttons, plus a central reference button. These assist in making set up easier in dark environments or if the projector is ceiling mounted.
  • Best in class color accuracy
    ViewSonic's exclusive SuperColor Technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness with the highest color saturation over others in the same class.
  • Bright images for any environment
    Packed with 3,100 lumens the PJD5250 is guaranteed to produce bright images in any environment - even in rooms with high ambient light. An impressive 18,000:1 contrast ratio also ensures that dark and bright areas are more black and white and less gray in appearance.
  • Easy-of-use pre-set color modes
    Providing 5 pre-set color modes, users can choose the best one to suit their material. These 5 modes are: Brightest Mode for environments where extra-high brightness is required; Dynamic Mode for presentations with a lot of text; Standard Mode for matching PC or notebook color; ViewMatch Mode for general viewing; Movie Mode for watching movies with better saturation in a dark environments.
  • Quickly access your favorite features with "my button"
    Finding a function through the on-screen menu can be time-consuming. The "My Button" button on the remote control is a programmable shortcut button that can be user-programmed to launch any desired function.
  • Keystone distorted image correction
    The PJD5250 can correct and adjust vertical distorted images into a more symmetric shape.
ViewSonic LightStream PJD5250 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Europe
Brightness
3100 ANSI lumens
Contrast Ratio
18000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
Component video
260 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.1 kg
DLP projector
3D Capable
Europe
Projector
Brightness
3100 ANSI lumens
Contrast Ratio
18000:1 (dynamic)
Image Size
76.2 cm - 762 cm
Throw Ratio
1.86 - 2.04:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
DLP 3D Ready, Super Color, DynamicEco Mode, Auto Power Off, Presentation Timer, auto power on, sleep timer, My Button
Lens
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Component video
Video Interfaces
VGA
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Power Source
AC
260 Watt
Power Consumption Stand by
0.5 Watt
31.6 cm
22.8 cm
10.37 cm
2.1 kg
Sound Emission
32 dB
27 dB
