ViewSonic's PJD5 series features DynamicEco technology to automatically adjust lamp brightness and thereby extend lamp life to 6000 hours. Requiring only 0.5W power consumption in standby mode, the PJD5 series lowers the total ownership cost, making it a budgetfriendly option. This series has a slim and portable design that weighs less than 5 pounds. Boasting BrilliantColor technology, 2,800 lumens, and 15,000:1 contrast ratio, the PJD5 series delivers clear, crisp images and vivid, accurate colors, while supporting a variety of resolutions, to best meet the environmental requirements of any professional presentation. The HDMI connection, multiple video input options and integrated speakers in the PJD5 series provide flexible connections to a variety of devices. Additionally, the Off-to-Go mode, vertical keystone correction, and 120 Hz/3D ready functions allow the operation of this projector series to be simple and efficient, making business presentations convenient, smart, and easy.
High brightness and contrast ratio ensures the stunning image quality
The PJD5 series carries a variety of models with a versatile range of resolutions to cater to specific image quality requirements. It will support 2,800 lumens brightness and 15,000:1 contrast, ensuring the image quality will remain crystal clear and vivid even in the bright environments. -
DynamicEco technology makes excellent energy conservation
ViewSonic's proprietary DynamicEco technology will automatically adjust lamp brightness to render a longer projector lamp life and conserve up to 70% power consumption. -
BrilliantColor technology delivers vivid color to the life
ViewSonic integrates BrilliantColor technology into the PJD5 series to construct digital colors that deliver stunning and vivid images. The advanced 6-segment color wheel enriches the performance of the yellow color and further augments overall color reproduction to present defined picture quality. -
6000-hours high performance long-life light bulbs
The energy-saving mode on the PJD5 series automatically adjusts the brightness, which extends the lamp light to up to 6,000 hours and saves on maintenance costs. -
Ultra-low power consumption in standby mode
The PJD5 series consumes only 0.5W in standby mode, saving ownership cost and practicing environmental friendliness. -
Off-to-Go mode saves your time
The efficient Off-to-Go mode on the PJD5 series enables quick shutdown and turn-on, saving every second of your valuable time. The PJD5 series takes only 3 seconds to turn on, while shutting down instantly and requiring zero power consumption to cool down the projector. -
Easy vertical keystone correction
When projectors are tilted, the projection image aspect ratio may display rectangular images in a trapezoidal shape, resulting in image distortion. The PJD5 series offers +40°/-40° keystone correction to fix projected image distortion issues easily and quickly. -
3D projection ready HDMI input
The 3D DLP Link technology supports an image update frequency of 120 Hz, allowing the projected image to be shown with a 3D stereoscopic effect. Along with HDMI, the PJD5 series brings supreme images onto a large screen.
- ViewSonic PJD5234 - DLP projector - 3D - black
- DLP projector
- 3D Capable
- Black
- Microdisplay
- DMD Chip
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 315 Watt
- 29.4 cm x 20.2 cm x 9.5 cm
- DLP projector
- 3D Capable
- Enclosure Colour
- Black
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 70 cm - 539 cm
- Projection Distance
- 1.2 m - 10 m
- Throw Ratio
- 1.97 - 2.17:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- 6-segment colour wheel, BrilliantColor, DLP 3D Ready, DynamicEco Mode
Lens
- Zoom Factor
- 1.1x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- Speakers
- 2 x right / left channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) (management) , 1 x USB - mini-USB Type B , 1 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- UL, TUV GS, C-Tick, cUL, ICES-003, NOM, SASO, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, UkrSEPRO, KC, CECP
- Voltage Required
- 315 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 29.4 cm
- 20.2 cm
- 9.5 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
