The ViewSonic LightStream Projector PJD5151, the best price-performance projector, is designed with elegant style and impressive image performance. This sleek projector makes a big statement with its elegant curves and light beam shape. It's thoughtful design, which includes a tactile keypad, instructional icons, and son on, also presents an intuitive and user-friendly interface. Exclusive SuperColor technology offers a 6-Segment Color Wheel - 15%+ color brightness, for true-to-life image projection. The 3,300-lumen lamp with a 22,000:1 contrast ratio is for clearer and brighter images. From small meeting rooms to small classrooms, LightStream Projector PJD5151 projects full brightness and colors.
Best in class color accuracy
ViewSonic's proprietary SuperColor Technology offers a wider color range than conventional DLP projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness Increased by 15% or more with the highest color saturation over others in the same class. -
Smart restart instant reactivation during presentation
With Smart Restart, the projector automatically enters a 3-minute standby mode when it is idle and turns down the projection to a power-saving 30% brightness. During standby mode, you can quickly and conveniently reactivate the projector for continued use without waiting for a complete power cycle. -
Auto power on instant activation upon signal connection
With Auto Power On enabled, once a VGA or HDMI cable is connected and signal detected, LightStream projectors will power on automatically with effortless start-up. -
Auto power off
Power Saving: Every Time When no signal is detected, the projector will automatically power off after a user-defined amount of time - another feature to save electricity cost, reduce energy consumption and extend the life of the projector. -
Quick power off leave without the wait
Quick shut down in seconds because of smart electric and lamp designs are time-saving improvements that lead towards efficiency and energy savings. -
Mouse-like control handy operation
Mouse left and right-click buttons are provided on the remote control so users can use a single remote control to navigate through presentation slides or control the connected PC. -
Top lamp door
The thoughtfully designed lamp door makes lamp maintenance and replacement easy. Located at the top of the projector, there's no need to dismantle the projector, even if it's hanging from the ceiling, to access the lamp. This user-friendly design saves time and effort for maintenance personnel in businesses and schools, and is easy enough that just about anyone can do it. -
Presenter timer reminder for time management
An embedded on-screen timer assists presenters to manage their times to avoid presentation over-runs that cause potential delays during scheduled sessions. -
Tactile keypads
Tactile Keypads reflect LightStream Projectors' detailed design to the most LightStream Projectors' tactile keypad is raised with concave buttons that assist in making projector set up easier in dark environments without illumination. Also, Touching and feeling the non-flat keypads can be also interesting.
- ViewSonic LightStream PJD5151 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Localisation
- Europe
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Power
- AC 120/230 V (50/60 Hz)
- 260 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.2 kg
- DLP projector
- 3D Capable
- Localisation
- Europe
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 1.86 - 2.04
- Digital Zoom Factor
- 2x
- Resolution
- SVGA - SVGA (800 x 600)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- 6-segment colour wheel, DLP 3D Ready, Super Color, Auto Power Off, Presentation Timer, auto power on, sleep timer, My Button
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 260 Watt
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.2 kg
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 27 dB
