The ViewSonic PJD5132 is a high-performance SVGA 800 x 600 DLP projector with 3000 ANSI lumens and 15,000:1 contrast ratio. With DynamicEco technology, presenters can put the projector in "standby" mode by reducing brightness down to 30% when they need to shift audience's focus without restarting the projector. This projector offers a variety of hardware and software features including multiple PC and video input options, 1.1x optical zoom, keystone correction, PC 3D-ready/120 Hz, HD video support and integrated speaker. Filter-less design and energy-saving Eco-mode provide for virtually zero maintenance and increased product reliability. The PJD5132 lightweight design is ideal for tabletop use or mounting on a ceiling in both classrooms and corporate offices.
3000 lumens, native resolution 800 x 600, contrast ratio 15,000:1 (with DynamicEco™), ~2.1Kg, 2 x RGB in, 1 x RGB out, 1 x S-Video, 1 x Composite, Audio in/out. Throw ratio 1.86:1 - 2.04:1. 2 x 2W speaker, 3D Ready DLP Link, up to 5000/10,000 hours lamp life (on Eco Mode)
3000 lumens shines in virtually any setting
Uses less watts per lumen than other comparable projectors. And with 15000:1 contrast (with DynamicEco), the PJD5132 is the bright choice for business and education. -
DLP technology
Advanced DLP (Digital Light Processing) technology allows you to experience crystal clear, razor-sharp and lifelike images with the same DLP technology that Hollywood relies on. For fast action, the response time is also on the order of 1,000 times faster than similar LCD based projectors. And with no air filters to clean or change, the latest generation of DLP based projectors from ViewSonic offer amongst the lowest TCO (Total Cost of Ownership) in the industry. -
BrilliantColor technology
ViewSonic's PJD5132 projector with BrilliantColor technology features multi-color processing to produce stunning, vibrant colors. Unlike other technologies such as LCD which use just 3 primary colors to produce the image, the PJD5132 uses up to 6 separate colors. The sophisticated 6-segment color wheel enhances the yellow color performance that is the key to accurate and vivid color reproduction. With multi-color processing, colors are richer and more vibrant with exquisite and precise detail. -
Maintenance free with filter-less design
ViewSonic's PJD5132 projector features a filter-less design. Unlike LCD projectors that require the user to clean, sometimes to replace, filters after every 100 to 300 hours of operation, ViewSonic's PJD5132 projector is filter-less, eliminating the need for filter cleaning or filter replacement. This saves you significant maintenance dollars and labor over the projector's lifespan, and lowers your total cost of ownership (TCO). -
Long-lasting reliable picture quality and superior color performance
ViewSonic DLP projectors provide reliable picture quality you can trust and superior color performance you can count on after thousands of hours of usage. Built on DLP technology, the ViewSonic PJD5132 projector virtually eliminates image degradation known as color decay - yellow/faded tint that LCD projectors may develop after extended use. Even after years of use, the PJD5132 is still producing a stunning, sharp image that lasts. -
DynamicEco technology for total control of audience's focus
With the DynamicEcobutton on the remote, take command of presentations by dimming the screen imageup to 70%. The projector will also auto activate DynamicEco when the unit is not in use. When DynamicEco is activated, the lamp's power consumption is significantly reduced- a great energy-saving design for a low total cost of ownership (TCO).
- ViewSonic PJD5132 - DLP projector - 3D
- DLP projector
- 3D Capable
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 250 Watt
- 26.8 cm x 22.1 cm x 8.44 cm
- 2.1 kg
- DLP projector
- 3D Capable
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 60 cm - 760 cm
- Projection Distance
- 1 m - 11.3 m
- Throw Ratio
- 1.86 - 2.04:1
- Resolution
- SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, 6-segment colour wheel, BrilliantColor, DLP 3D Ready, DynamicEco Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- Video Modes
Speakers
- Internal
- Output Power / Channel
- 2 Watt
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- UL, TUV GS, C-Tick, cUL, ICES-003, NOM, SASO, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, UkrSEPRO, KC, CECP
- Voltage Required
- 250 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- Software Included
- ViewSonic Wizard
- 26.8 cm
- 22.1 cm
- 8.44 cm
- 2.1 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 29 dB
