The ViewSonic CDE6552-TL is an ideal large format interactive solution for classrooms and meeting room. The multiple touch allows two users to simultaneously write or draw on the board with their fingers or styli. A Full HD LED screen guarantees crisp and vivid content. Visually attractive. Create a more interactive learning and meeting environment with this ViewSonic 65" ViewBoard!
Multiple-touch capable interactive display
ViewSonic large-format interactive touch displays provide up to 4-point and up to 6-point simultaneous touch capability - making it perfect for educational and corporate meeting applications. This feature allows 2 or 3 people to simultaneously write on the display's surface using their fingers or styli. -
Protective rounded-corner design
Providing a safer learning environment for active students is also an important consideration. That's why ViewSonic large-format interactive touch displays utilize a rounded-corner design to help prevent injuries in the classroom. -
Tough anti-scratch, anti-glare cover
ViewSonic large-format touch displays are made even more durable by a layer of 7H-hardness tempered glass coupled with an anti-glare film. This material combination provides anti-scratch benefits, while improving screen visibility in bright environments.
- ViewSonic CDE6552-TL 65" Class (64.53" viewable) LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Diagonal Size
- 64.53"
- Commercial Use
- Yes - interactive
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 4 ports
- Included Accessories
- Remote control, wall mounting bracket, moving display mounting cart
- Voltage
- AC 120/230 V (50/60 Hz)
- 150 Watt
- Power Consumption Stand by
- 0.5 Watt
- 136.9 cm x 10.4 cm x 82.8 cm
- 47 kg
- Product Type
- 150 Watt
- Diagonal Class
- 65"
- Diagonal Size
- 64.53"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Landscape mode
- Protection
- Anti-scratch display
- 136.9 cm
- 10.4 cm
- 82.8 cm
- 47 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 4000:1
- Brightness
- 400 cd/m²
- Touchpoints Qty
- 4
- Backlight Life
- 30,000 hour(s)
- Infrared touch technology, e-LED BLU
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 4
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 30 Watt
- Speakers
- 2 x main channel speaker - 15 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- 2 x HDMI input , 2 x VGA input , 2 x audio input , S-Video input , Composite video input , Composite video output , Audio input , Component video input , USB , SPDIF output , Serial input , Headphones , Microphone , VGA output , LAN , 4 x USB 2.0 , USB
- Wall mounting bracket, moving display mounting cart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 148 cm
- Depth (Shipping)
- 30.7 cm
- Height (Shipping)
- 98.7 cm
- Weight (Shipping)
- 55 kg
