Veho Wireless Speaker System including transmitting Dongle
Quicklinx: BHMBWS00 Mfr#: VSS-003W-X1
The X-1 series speaker utilizes 2.4 Ghz wireless technology to transmit clear and crisp sound to the portable X1 speaker system.The X series range utilizes 2.4 GHz Wi-Fi, Lithium polymer rechargeable batteries and transmitting dongles for PC and Mac for a completely wire-free listening experience.
The internal rechargeable battery allows up to 8 hours wireless playback and coupled with the 3.5mm line in can be used in conjunction with your iPhone/iPod/MP3 player when you are on your travels.
The X series speakers' transmitting dongles that ship with the system utilize their own 2.4 GHz wireless frequency to create their own wireless network. This means there is no requirement for existing routers or WiFi network. It's as simple as plug and play!
Utilize the free Apple Remote App or Spotify App for iPhone/iPod Touch/iPad and you can control your music from most smartphones without the need for any dongles. The Apple Remote App is a free, fun, and easy-to-use app that turns your iPhone, iPad, or iPod touch into a remote control. So wherever you are in your house, you can control your computer's iTunes library with a tap or flick of a finger.
Veho Mimi X1 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
4 Watt
Peak Power
5 Watt
Amplifier
Integrated
Wi-Fi
Speaker Details
Speaker - stereo x 2 - 2 Watt - 150 - 18000 Hz - 4 Ohm - active
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
8.8 cm
Dimensions - Diameter
7 cm
Speaker System
Speaker Type
Active
Continuous Power
4 Watt
Peak Power
5 Watt
Signal-To-Noise Ratio
80 dB
Max Output Level (Max SPL)
85 dB
Sensitivity
78 dB
Amplifier
Integrated
Wi-Fi
Transmission Range
30 m
Controls
Power on/off, volume
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 2 Watt - 150 - 18000 Hz CFR - 4 Ohm - active
Driver Details
Speaker: full-range driver - 1.5" - ferrite - paper
Connector Type
Audio line-in (mini-phone 3.5mm)
Audio cable, wireless transmitter, extension unit, USB charging cable
Power Source
Options
USB charging
Rechargeable - lithium polymer
Capacity (Ah)
800 mAh
Run Time (Up To)
4 hour(s)
Diameter
7 cm
8.8 cm
