Veho 360 WHITE M4 BLUETOOTH SPEAKER
Quicklinx: 93TGWS00 Mfr#: VSS-747-360BT
The 360° M4 Bluetooth Speaker follows on from the successful VSS-006-360BT 360° M3 Bluetooth Speaker but introduces duel 2 x 2.2 w speaker power and includes a microSD card slot and volume/track control.
The 360° M4 Bluetooth Wireless Speaker remains totally portable standing only 6.5 cm high with a diameter of 5.5 cm and contains a 600 mAh rechargeable battery that allows playback of up to 6 hrs. The M4 also ships with a standard 3.5 mm line in cable to use with any standard non Bluetooth device, mini USB charging cable and also a funky protective carry sock.
Sound output on the 360° M4 Bluetooth Wireless Speaker is doubled boosted by two 2.2 watt speakers and for convenience volume and track control are located on the speaker so you can control your music from the speaker whether you are using Bluetooth wireless or the micro SD port located on the speaker.
Veho M-4 - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
Flash memory card
Speaker Type
Active
Nominal Output Power (Total)
4.4 Watt
Bluetooth
Audio Formats
MP3, WMV (Sound)
Speaker Details
Speaker - stereo x 2 - 2.2 Watt - active
Ice white
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
6.5 cm
Dimensions - Diameter
5.5 cm
Flash memory card
Enclosure Colour
Ice white
Speaker System
Speaker Type
Active
Audio System Continuous Power (Total)
4.4 Watt
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Audio Formats
MP3, WMV (Sound)
Controls
Volume
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, protective case, USB charging cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
600 mAh
Run Time (Up To)
6 hour(s)
Diameter
5.5 cm
6.5 cm
