These medium sized USB optical LED mice have a contoured, aesthetically pleasing two-tone style, in red, blue or silver color options. The high quality space saving 3 button design includes a built-in scroll wheel and textured side grips for long lasting comfort in either hand. The 1000 dpi optical sensor provides precise and swift cursor movement for easy smooth navigation. The cable length with Plug and Play USB connection is the perfect size to stow away in your laptop case when traveling between your home and office or for business.
- V7 MID SIZE USB OPTICAL LED MICE - mouse - USB - blue
- Mouse
- Connectivity Technology
- Wired - USB
- Blue
- 5.7 cm x 10.1 cm x 3.8 cm
- 71.1 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- Cables Included
- 1 x USB cable - integrated - 1.52 m
- OS Required
- Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- 5.7 cm
- 10.1 cm
- 3.8 cm
- 71.1 g
- Blue
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Scrolling wheel
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- OS Required
- Limited warranty - 2 years
