Now you can take your music anywhere you go with the V7 Water-resistant and rugged Bluetooth wireless Speaker. It's the ideal companion for beach, hot tub pool party, picnic or simply just singing in the shower. It's so versatile that you can even use the keychain hook to attach to your backpack while you hike. Built-in rechargeable lithium ion battery keeps the music flowing for 2 - 3 hours. Bluetooth technology has a wireless range of 30 ft and makes connection to your mobile device such as Apple iPad, iPhone, iPod touch, Android devices and more simple.
- V7 SP5100 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Black
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 7.37 cm x 8.38 cm x 11.4 cm
- 195 g
- Product Type
- Protection
- Waterproof
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Transmission Range
- 9.75 m
- Controls
- Power on/off, volume, call answer, activate Bluetooth
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 3 hour(s)
- 7.37 cm
- 8.38 cm
- 11.4 cm
- 195 g
