The 8-port USB KVM switch lets you manage multiple computers with just one set of keyboard, monitor and mouse. This rack mount device supports USB and PS/2 interface on the console side and USB only on the PC side. Popular hardware platforms such as PC, Linux and Mac are supported. Users can switch between PCs using hot-key or push button for flexible management. Users can also hot-plug PCs on the fly to avoid downtime. The 8-port USB KVM switch is the perfect choice for managing multiple PC's.
- TRENDnet TK 803R - KVM switch - 8 ports - rack-mountable - TAA Compliant
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- Firmware upgradable
- USB 1.1
- 40.7 cm x 16.5 cm x 4.5 cm
- 1.8 kg
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 2048 x 1536
- USB 1.1
- Status Indicators
- Active, select
- 8 x KVM DB-15 , 1 x VGA HD-15 , 1 x mouse (PS/2) , 1 x mouse (USB) Type A , 1 x keyboard (PS/2) , 1 x keyboard (USB) Type A
- Power Device
- External power adapter
- Rack Mounting Kit
- Included
- Plug and Play, FCC, RoHS
- TAA Compliant
- OS Required
- 40.7 cm
- 16.5 cm
- 4.5 cm
- 1.8 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
