TRENDnet 4-Port Broadband Router
Quicklinx: 9YLDWS00 Mfr#: TW100-S4W1CA
TRENDnet's TW100-S4W1CA 4-port DSL/Cable Modem Internet Station provides the easiest and securest way to share your high-speed cable/xDSL Internet connection. It has four 10/100Mbps half/full duplex switch ports that provide direct connection to workstations or uplinks to other hubs or switches. It allows up to 128 users to access the Internet through the same ISP account. By sharing just one TW100-S4W1CA, one IP address, and one cable/xDSL modem, dozens of network users can surf the Internet at the same time. The TW100-S4W1CA also functions as a firewall for your network, protecting your computers from hackers. TRENDnet's DSL/Cable Modem Internet Station is a feature-rich product that provides cost saving functions and easy configuration.
TRENDnet TW100-S4W1CA - router - desktop
Router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Network / Transport Protocol
TCP/IP
Uplink, firewall protection, switching, IP-routing, DHCP support, NAT support
IEEE 802.3, IEEE 802.3u
AC 110/220 V (50/60 Hz)
Blue
16 cm x 10.4 cm x 2.6 cm
218 g
UNIX, Microsoft Windows 95/98, Apple MacOS, Microsoft Windows 2000 / NT4.0
Router
Enclosure Type
Desktop
Wired
Data Transfer Rate
100 Mbps
TCP/IP
Built-in Devices
Led panel
Status Indicators
Power, link/activity
4 x 10Base-T/100Base-TX - RJ-45 - 4 , Management: 1 x RS-232 - 9 pin D-Sub (DB-9) - 1 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
External power adapter
Enclosure Colour
Blue
Software Included
Drivers & Utilities
16 cm
10.4 cm
2.6 cm
218 g
Limited warranty - parts and labour - lifetime - carry-in
50 °C
0 - 90%
