The 16-port 10/100 Mbps PoE+ switch, model TPE-T160H, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as access points and IP cameras. It supplies up to 30 Watts of power per port with a 250 Watt power budget.
- TRENDnet TPE T160H - switch - 16 ports - rack-mountable
- Switch - 16 ports
- Enclosure Type
- Rack-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 250 W
- Performance
- Switching capacity: 3.2 Gbps , Forwarding performance (64-byte packet size): 2.38 Mpps
- MAC Address Table Size
- 4K entries
- Half duplex mode, full duplex mode, GREENnet technology, 1.25MB packet buffer
- IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 22 cm x 4.4 cm
- 3 kg
- 3-year warranty
- Switch - 16 ports
- Enclosure Type
- Rack-mountable
- Subtype
- Fast Ethernet
- Ports
- PoE+
- PoE Budget
- 250 W
- Performance
- 4K entries
- 16 x 100Base-TX RJ-45 PoE+ - 30 W
- Power Device
- Internal power supply
- Voltage Required
- 260 Watt
- Rack Mounting Kit
- Included
- FCC
- 44 cm
- 22 cm
- 4.4 cm
- 3 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
