TP LINK TL-WR841HP 300Mbps High Power Wireless N Router
Quicklinx: 8WCCWS00 Mfr#: TL-WR841HP
  • IEEE 802.11n
300Mbps High Power Wireless N Router TL-WR841HP is a powerful wireless solution well suited for the home or office. With 300Mbps wireless speeds, TL-WR841HP is ideal for streaming HD video, making VoIP calls and online gaming. What's more, featured with high power amplifier, 25dBi antennas and up to 1000mW1 transmission Power, the device greatly boosts Wi-Fi performance.
4x Range
High power amplifier and 5dBi antennas provide 4x* the wireless range of a normal router, with the TL-WR841HP, you can enjoy your wireless network not only in restricted indoor areas but also in your backyard or even by the pool.
*Actual transmission power may be legally limited in certain regions.
Wall Penetrating Wi-Fi
Enhanced Wi-Fi signal provides incredibly strong penetrability, cutting through walls and obstacles, eliminating dead zones, with which, you don't have to be physically tethered to the walls or floors to access the Internet.
2x Speed
2x* the wireless speed of a normal router over long-distances allows for seamless data transfers and media streaming across your network. You no longer have to endure poor wireless performance over long distances.
* Actual performance may vary due to differences in operating environments, building materials and wireless obstructions.
Wireless Speed up to 300Mbps
With Wireless N technology, TL-WR841HP provides much higher speed and better coverage than traditional 11G products. Speed up to 300Mbps makes it ideal for video streaming, online gaming and Internet calls.
WPS - One Button Security
The TL-WR841HP features Wi-Fi Protected Setup™ (WPS) that allows users to almost instantly setup their security simply by pressing the "WPS" button on their router, automatically establishing a WPA2 secure connection, which provides improved security compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Easy Setup
The device comes with a CD with an Easy Setup Assistant that leads you through the setup process step-by-step, and even helps with wireless network settings and security configurations, so even novice users can set up their networks in a flash.
  • Wall penetrating Wi-Fi
  • Wireless speed up to 300 Mbps
    With Wireless N technology, TL-WR841HP provides much higher speed and better coverage than traditional 11G products. Speed up to 300 Mbps makes it ideal for video streaming, online gaming and Internet calls.
  • WPS - one button security
    The TL-WR841HP features Wi-Fi Protected Setup (WPS) that allows users to almost instantly setup their security simply by pressing the "WPS" button on their router, automatically establishing a WPA2 secure connection, which provides improved security compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
TP-Link TL-WR841HP 300Mbps High Power Wireless N Router - wireless router - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, DMZ port, dynamic DNS server, manageable, MAC address filtering, Wireless Distribution System (WDS) support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, bandwidth control, port triggering, IP-MAC binding, DHCP client
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
16.85 cm x 13 cm x 3.15 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, FCC, RoHS
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
Software Included
Drivers & Utilities
16.85 cm
13 cm
3.15 cm
10 - 90%
8WCC C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
