The TL-WA5110G High Power Wireless Access Point is dedicated to Small Office/Home Office (SOHO) and long distance wireless network solutions. It integrates the functions of a Wireless Access Point, WISP Client, Firewall, and Router.
Long Distance Wireless Connectivity
The High Power Wireless Access Point features high output power and high RX sensitivity can significantly extend the transmission range to reduce dead spots and to deliver a more stable wireless connection. Also supports distance control from 0km to 52.6km, which breaks through distance limitations in normal 802.11g devices, enables ultra-long distance wireless transmission.
Easy To Use
The TL-WA5110G is easy-to-manage. Quick Setup is supported and friendly help messages are provided for every step. So you can configure it conveniently and share the Internet more quickly and easily.
Multiple Operation Modes
The TL-WA5110G provides three operation modes for multiple users to access the Internet: AP client router, AP router and AP. In AP client router mode, it works as a WISP CPE. In AP router mode, it can access the Internet via an ADSL/Cable Modem. In AP mode it can work in various modes, such as Access Point/Client/WDS Bridge/Repeater.
Versatile Access Point
- Bundled antenna alignment tool, which enables the best transmission and reception signals for superior wireless performance.
- Bundled power injector also provides flexible installation options in hard-to-wire locations.
- Integrated two useful tools: Speed Test and Throughput Monitor, user can easily get the operation information of access point without setup professional test software.
- Supports Ping Watch Dog which enables the device to reboot itself if the device has any errors. This self-recover feature reduces the time spent manually configuring the device.
- Bundled Client Isolation function protects the security and privacy of each individual subscriber. Therefore, subscriber does not need to worry about hacker attacks in the same wireless network.
WPA / WPA2 Encryptions - Advanced Security
With the most attentive wireless security, the TL-WA5110G 54M High Power Wireless Access Point provides multiple protection measures. It can be set to turn off wireless network name (SSID) broadcast so that only stations that have the SSID can be connected. The AP provides wireless LAN 64/128/152-bit WEP encryption security, and WPA/WPA2 and WPA-PSK/WPA2-PSK authentication, as well as TKIP/AES encryption security.
Long distance wireless connectivity
The high power wireless access point features high output power and high RX sensitivity can significantly extend the transmission range to reduce dead spots and to deliver a more stable wireless connection. -
Multiple operation modes
The TL-WA5110G provides three operation modes for multiple users to access the Internet: AP client router, AP router and AP. In AP client router mode, it works as a WISP CPE. In AP router mode, it can access the Internet via an ADSL/Cable Modem. In AP mode it can work in various modes, such as Access Point/Client/WDS Bridge/Repeater. -
Security
With the most attentive wireless security, the TL-WA5110G 54M high power wireless access point provides multiple protection measures. It can be set to turn off wireless network name (SSID) broadcast so that only stations that have the SSID can be connected. The AP provides wireless LAN 64/128/152-bit WEP encryption security, and WPA/WPA2 and WPA-PSK/WPA2-PSK authentication, as well as TKIP/AES encryption security. -
Easy to use
The TL-WA5110G is easy-to-manage. Quick setup is supported and friendly help messages are provided for every step. So you can configure it conveniently and share the Internet more quickly and easily.
- TP-Link TL-WA5110G - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 16.5 cm x 10.8 mm x 2.8 cm
- 16.5 cm
- 10.8 mm
- 2.8 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Cable(s) / Media Type Supported
- Ethernet 100Base-TX cable
- Data Transfer Rate
- 54 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- DSSS
- TCP/IP, PPPoE, DHCP, DNS
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 50 km
- Status Indicators
- Power, system, link/activity
- NAT support, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, Access Control List (ACL) support, virtual server support, DHCP server
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11g, UPnP
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Directivity
- Omni-directional
- Gain Level
- 4 dBi
- 1 x 100Base-TX - RJ-45 , 1 x aerial
- FCC
- PoE
- Power Device
- External power adapter
- -10 °C
- 40 °C
- 10 - 90%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
