TP LINK RE350 Universal Dual Band WiFi Range Extender
Quicklinx: CM9TWS00 Mfr#: RE350
  • IEEE 802.11n
The TP-Link AC1200 Wi-Fi Range Extender connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own. The device also reduces signal interference to ensure reliable Wi-Fi coverage throughout your home or office.
  • Blazing fast Wi-Fi speed
    Provides faster dual band Wi-Fi access with Wi-Fi standard - 802.11ac technology.
  • Gigabit Ethernet port
    Act as a wireless adapter to connect wired devices at gigabit speed.
  • Reliable connection
    Dual adjustable external antennas for optimal Wi-Fi coverage and reliable wireless connections.
  • Simultaneous dual band
    Reduces interference for more stable connections.
  • Smart signal indicator
    Smart signal lights help to find the best location for optimal Wi-Fi coverage by showing the signal strength.
  • One button easy setup
    Press the WPS button on both your router and your RE350 to easily get the Wi-Fi expanded in minutes.
  • Universal compatible
    Works with any Wi-Fi router or wireless access point.
TP-Link RE350 - Wi-Fi range extender - Wi-Fi 5
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
7.5 cm x 4.3 cm x 12.6 cm
7.5 cm
4.3 cm
12.6 cm
External
Wireless, wired
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Access Point operational mode, reset button, wireless extender mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 1000Base-T - RJ-45
1 x network cable
FCC, RoHS
Internal power supply
11 Watt
10 - 90% (non-condensing)
