Imagine bringing all of your home or office's Internet-enabled devices into the world of wireless. By connecting them to this entertainment adapter, the devices in your home that previously required running Ethernet cables around furniture, through walls and doorways can now be connected to your network wirelessly, without the risk of degrading performance. With N600 dual band wireless speeds and four LAN ports, TL-WA890EA provides your devices with ample bandwidth for smooth HD video and music streaming and online gaming.
Wireless Connectivity for Game Consoles, Smart TV and So On
The Entertainment Adapter can function as a wireless adapter to connect wired devices far away from a Router where running an Ethernet cable would be messy and troublesome. With 4 ports, you can instantly connect up to 4 Ethernet-enabled devices like Blu-ray® players, gaming consoles, DVRs, IPTV Set-top-box, printers and Smart TVs.
N600 Wireless Speeds
With 300Mbps at 5GHz for clear wireless transmission or 300 Mbps at 2.4GHz, those devices in your home that previously required Ethernet cables to connect to the network can now be connected to your network wirelessly, without the risk of degrading performance.
Easy wireless security encryption at a push of the WPS button
Within range of the existing wireless network, just push the paired "WPS" button on the router followed by the Entertainment Adapter or vice versa, and the device will automatically establish a WPA2 secure connection with the router.
What's more, the device can remember previously paired wireless networks, meaning there is no need to reconfigure the device when transferring outlets within wireless range.
Universal Compatibility
Works with any device with an Ethernet port, and seamlessly with all 802.11 a/b/g/n wireless devices. It is also compatible with the latest Windows 8 operating system. You no longer need to buy an individual proprietary Wi-Fi Adapter for each device that you want to enable with wireless.
Wireless connectivity for wired devices
The entertainment adapter can function as a wireless adapter to connect wired devices far away from a Router where running an Ethernet cable would be messy and troublesome. With 4 ports, you can instantly connect up to 4 Ethernet-enabled devices like Blu-ray players, gaming consoles, DVRs, IPTV set-top-box, printers and smart TVs. -
N600 wireless speeds
With N600 dual band speeds of 300 Mbps at 2.4 GHz and an additional 300 Mbps at 5 GHz, those devices in your home that previously required Ethernet cables to connect to the network can now be connected to your network wirelessly, without the risk of degrading performance. -
Within range of the existing wireless network, just push the paired "WPS" button on the router followed by the entertainment adapter or vice versa, and the device will automatically establish a WPA2 secure connection with the router. What's more, the device can remember previously paired wireless networks, meaning there is no need to reconfigure the device when transferring outlets within wireless range. -
Universal compatibility
Works with any device with an Ethernet port, and seamlessly with all 802.11 b/g/n wireless devices. You no longer need to buy an individual proprietary Wi-Fi adapter for each device that you want to enable with wireless.
- TP-Link TL-WA890EA - bridge - Wi-Fi - desktop
- Bridge - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- WMM support
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- 11.41 cm x 10.3 cm x 3.81 cm
- System Requirements
- UNIX, Apple MacOS, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7, Windows 8
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- WMM support
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 5 pin Micro-USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable , 1 x USB cable
- Software Included
- Drivers & Utilities
- OS Required
- 11.41 cm
- 10.3 cm
- 3.81 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
