The Archer C58 features the advanced Wi-Fi standard - 802.11ac, widely compatible with both wireless AC and wireless N devices. With this excellent technology, the Archer C58 offers you faster, stronger and more capable Wi-Fi. Simply put: an amazing network experience on all your devices.
Lightning Wi-Fi powers perfect entertainment
The Archer C58 provides your entire home with simultaneous dual-band Wi-Fi connections. The strong and stable 2.4 GHz wireless band is perfect for sending emails, browsing the web or listening to music. Meanwhile, the 5 GHz wireless band provides great Wi-Fi speed for latency-sensitive entertainment so you can stream HD video, play online games and hold video chats all at the same time, without delay. -
Strong signal, great coverage
The Archer C58's three high-performance external antennas ensure full home Wi-Fi coverage. Combined with a dual-band wireless network, its increased stability and range means you will no longer suffer from weak, dropped connections. -
Easy parental control
Supervise children and staff with responsible access, controlled by parents or administrators. Use URL blocking to easily set up a black or white list and limit the level of web access. -
Guest network access
Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security.
- TP-Link Archer C58 AC1350 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.35 Gbps
- PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
- DoS attack prevention, print server, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, Stateful Packet Inspection Firewall (SPIF), DHCP client
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 22.5 cm x 14.8 cm x 3.3 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.35 Gbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1350
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Built-in Devices
- Led panel
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 3
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 22.5 cm
- 14.8 cm
- 3.3 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
