The TL-R860 multifunctional broadband router is especially designed for SOHO (Small Office/Home Office) to access the Internet. It features strong functions, high performance, and easy configuration router. The TL-R860 provides many management functions.
The TL-R860 router provides flexible access control, limiting staff or children to browse selected sites. The TL-R860 router is also a smart helper. It connects to the Internet automatically on demand and disconnects when idle to save on network costs. It's easy to configure.
- TP-Link TL-R860 - router - desktop
- Router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet
- Data Transfer Rate
- 100 Mbps
- TCP/IP, L2TP, ICMP/IP, PPPoE, DHCP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- Firewall protection, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, IP address filtering, firmware upgradable, SNTP support, virtual server support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1x, UPnP
- 18.6 cm x 14.6 cm x 4.4 cm
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- 100 Mbps
- Routing Protocol
- Static IP routing
- HTTP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1x, UPnP, FCC
- Status Indicators
- 100M device connected, link/activity
- LAN: 8 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- External power adapter
- 18.6 cm
- 14.6 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
