TP LINK 48 Port Gigabit Smart Switch + 4 SFP slots
Quicklinx: 8QTPWS00 Mfr#: TL-SG2452
TP-LINK Gigabit Smart Switch TL-SG2452 is equipped with 48 Gigabit RJ45 ports and 4 SFP slots. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK Gigabit Smart Switch TL-SG2452 is a cost-eff­ective product solution for the small and medium business. TL-SG2452 has useful security features. The storm control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and gigabit capability, TP-LINK Gigabit Smart Switch TL-SG2452 provides you the ideal access-edge solution.
  • Advanced QoS features
    To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including Port Priority, 802.1P Priority and DSCP Priority, to ensure that voice and video are always clear, smooth and jitter free.
  • Abundant layer 2 features
    For more application of layer 2 switches, TL-SG2452 supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, port isolation, port mirroring, STP/RSTP/MSTP, link aggregation group and 802.3x flow control function. Any more, the switches provide advanced features for network maintenance such as loop back detection, cable diagnostics and IGMP snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
  • Enterprise level management features
    TL-SG2452 is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) or SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
TP-Link JetStream TL-SG2452 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Backplane switching capacity: 104 Gbps , Forwarding performance: 77.4 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP
Flow control, Layer 2 switching, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, Management Information Base (MIB)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
44 cm x 26 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Status Indicators
Power, system, 1000M device connected, link/activity
48 x 1000Base-T RJ-45 , 4 x Ethernet 1000 - SFP (mini-GBIC)
Internal power supply
4 rubber feet
Rack Mounting Kit
Included
FCC
Software Included
Drivers & Utilities
44 cm
26 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
8QTP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
