Your basket is empty
TP LINK 2.4GHz 3dBi Desktop 3-Antenna Lotus Design 1m cable
Quicklinx: 8985WS00 Mfr#: TL-ANT2403N
2 in stock
£7.90 ex VAT
£9.48 inc VAT
Wireless N desktop antenna TL-ANT2403N operates in the 2.4-2.5 GHz band and provides 3 dBi omni-directional operation, to extend the wireless range. The antenna offers three RP-SMA male connectors, which could effectively connect with all the 3T3R routers, access points or adapters to upgrade the wireless performance. Also, the desktop design and the bundled low-loss cable ensure its flexible deployment and stable signal.
TP-LINK TL-ANT2403N - antenna
Antenna
Application
Indoor
Placing / Mounting
Desktop
Directivity
Omni-directional
Compatibility
802.11n
Frequency Range
2.4 - 2.5 GHz
Gain
3 dBi
Plug and Play, RoHS, WEEE
Antenna
Cable Length
1 m
Aerial
Application
Indoor
Placing / Mounting
Desktop
Directivity
Omni-directional
Compatibility
802.11n
Frequency Range
2.4 - 2.5 GHz
Gain
3 dBi
Voltage Standing Wave Ratio (VSWR)
1.92:1
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
3 x RP-SMA male
-20 °C
60 °C
10 - 90% (non-condensing)
Brand: TP LINK
Price Range Ex VAT: 0 - 50
