Satellite Pro R50-B - DESIGNED FOR BUSINESS
Regardless of your business' size, this slim, smart and reliable laptop will help to meet all your requirements. Feature-rich yet reasonably-priced, Toshiba has put more into the 39.6 cm (15.6") Satellite Pro R50-B, so you can get more out. It's more reliable, thanks to a durable design that's ready to take on the pressures of your working life. It offers more connectivity for the freedom to work how you want to - whether that's using office peripherals via two USB 3.0 ports, or making a presentation on an external display with HDMI or RGB. Plus, the laptop comes with more ways to manage your workload - from fast network access through Gigabit LAN and Intel® Wi-Fi to a choice of powerful Intel® processors. And with a 39.6 cm (15.6") non-reflective HD display, you see every detail of your content in high definition. Wherever your working day takes you, the Satellite Pro R50-B was designed for business.
The Satellite Pro R50-B is built for Pros with Intel Inside®. The laptop has been designed, developed and manufactured by Toshiba to be more reliable for your business - whatever its size.
In fact we're so confident, that every Satellite Pro R50-B with an Intel® Core™i3 processor or Intel® Core™ i5 processor comes with our Reliability Guarantee - a promise that in the unlikely event of a failure, we'll repair your machine for free AND give you your money back*.
READY FOR ANY TEST
You can rely on the Satellite Pro R50-B to meet the demands of your busy working day. The device has passed rigorous stress testing by independent German test institute, TÜV Rheinland® - including a Highly Accelerated Life Test (H.A.L.T) that subjects the laptop to levels of vibration, shock, and temperature.
THINNER AND LIGHTER
With a sleek but sturdy design, the Satellite Pro R50-B is a portable office that you can take anywhere. Weighing just 2.3 kg, and measuring only 24 mm thin, the device's slim chassis is easy to carry and use.
THINNER AND LIGHTER
LONG LASTING BATTERY LIFE
Satellite Pro R50-B has a removable battery that lasts up to 7.5 hours - which means it'll keep going throughout your working day, with less need for charging.
KEEPS ACCESS UNDER CONTROL
Toshiba's exclusive BIOS fully protects your system against unauthorised access. Its Self-Anti-Tamper feature identifies attacks and prevents the machine from booting, so your laptop is fully protected at the deepest level.
PEACE OF MIND ONLINE
Satellite Pro R50-B comes with a free 30-day trial version of McAfee LiveSafe™ security pre-installed - to keep you protected online from the first boot-up onwards.
Long-lasting battery
Busy execs can enjoy unplugged freedom to stay productive for long hours with the removable battery. Plus, Toshiba's battery lifecycle eco-charging mode increases charging cycles by up to 40%. -
Keeps you productive
With its rigid and robust chassis, the Satellite Pro R50 has a proven low failure rate. It stands up to the rigors of daily business use, reducing IT maintenance and significantly lowering downtime. -
Built for business
The Satellite Pro R50 is designed, engineered, manufactured and tested by Toshiba to help you succeed in business. Enjoy the peace of mind that this reliable professional notebook keeps your business moving forwards. -
Smart, thin and light
The stylish, sturdy Satellite Pro R50 makes an elegant portable office for busy execs on the go. The ergonomically designed chassis is easy to carry and use, measuring only 24 mm slim. -
Proven reliability
The R50 is built to handle the rough and tumbles of life in the office and on the road. Toshiba's Highly Accelerated Life Testing (HALT) includes drop, impact and spill tests to build in world-class reliability. -
Portable with an odd
Unlike many ultraportable, the Satellite Pro R50 features a built-in DVD SuperMulti Drive, capable of reading and writing the most popular disc formats.
- Dynabook Toshiba Satellite Pro R50-B-12W - 15.6" - Intel Core i3 - 4005U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Processor
- Intel Core i3 (4th Gen) - 4005U / 1.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- ClickPad
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 7.42 hours
- Black, tile black (keyboard)
- 37.9 cm x 25.8 cm x 2.395 cm
- 2.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i3 (4th Gen) 4005U / 1.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Sound
- Stereo speakers, microphone
- High Definition Audio, DTS Sound
Input
- Keyboard, ClickPad
- Numeric Keypad
- Multi-touch clickpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 7.42 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- 2 x USB 3.0 , LAN , VGA , Headphone/microphone combo jack , HDMI , USB 2.0
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, Windows 8.1 Pro 64-bit (DVD)
- Case Material
- Polycarbonate ABS
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.3 kg
Sustainability Information
- ENERGY STAR Certified
