Toshiba Satellite Pro R50-B-123 Intel Core i5-4210U 8GB 1TB 15.6" Windows 8.1 64-bit
Quicklinx: 9T8YWS00 Mfr#: PSSG0E-009001EN
  • Core i5
  • Windows 8.1 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
DESIGNED FOR YOUR BUSINESS
Every element is designed to meet the needs of small and medium organisations like yours. By putting more into the Satellite Pro R50-B, Toshiba has made sure that you get more out of it - for an improved experience that delivers added value every time you use it. So the port layout is on the side of the laptop for easier access. The hinge has been positioned in a way that brings you added stability. And the black colour design with thin stripe doesn't just look smart, it offers increased resistance to fingerprint marks too. Designed, engineered and manufactured by the trusted partner for SMB, the Toshiba Satellite Pro R50-B is professional through and through.
MEETS THE DEMANDS OF YOUR DAY
You can rely on your Satellite Pro R50-B to meet the demands of your busy working day. It's already passed a combination of stress tests carried out by the independent German test institute, TÜV Rheinland®. Known as the Highly Accelerated Life Test (H.A.L.T), it mimics the lifecycle of your laptop by subjecting it to levels of vibration, heat, and pressure. So you know the durable R50-B can withstand unpredictable situations and weather conditions - ideal when you're on the move. Add to that the device's high stiffness design, which reduces bending, and you've got a machine that can stand up to daily use, time and time again. In fact, we're so confident in the quality of the R50-B that it even comes with a 1 year Toshiba Reliability Guarantee.
SMART STYLE
There's a lot more to the Satellite Pro R50-B than a slim, stylish and durable chassis. Open up the lid to reveal the tiled keyboard with numeric keypad, and you're all set to be more productive - without the need to plug in an external keypad. The full-size port layout includes RGB and HDMI too, so you won't have to carry adapters to connect to an external display. Plus, there's a 39.6 cm (15.6") non-reflective HD screen, so you're always free to focus on your business-critical content in clear high definition. With no glare to worry about, you can type emails or create documents in the office, outdoors or wherever's convenient.
MADE TO BE ON THE MOVE
With a sleek but sturdy design, the Satellite Pro R50-B is the portable office you will want to take everywhere. At just 2.3 kg, and only 24 mm thin, its slim chassis is as durable as it is stylish - and was made to be easy to carry and use. Essential for a busy working life that's constantly moving between your home, office and meetings, this business laptop has the flexibility, speed and strength to switch from task to task in any location.
PROFESSIONAL PERFORMANCE
The Satellite Pro R50-B comes with a variety of powerful processors for fast responses - and Intel® HD graphics 4400 for a smooth graphical performance. A High Speed HDD* is available to help you store your business files and critical data safely too. And with a removable, long-life battery, you're free to work wherever your business takes you.
SECURITY MANAGED
With Trusted Platform Module (TPM) secure hardware* on selected models you can be sure that your sensitive business data stays safe. The Satellite Pro R50-B also comes with a HDD 3D sensor for permanent data protection - and a 30-day trial version of McAfee Livesafe security is pre-installed to protect you from the first boot-up onwards.
BETTER CONNECTED
Whether you're working in the office, at home or on the way to a meeting, you can make the most of best-in-class connectivity to share information between devices. The Satellite Pro R50-B comes with Bluetooth® 4.0, plus Gigabit LAN and Intel® Wi-Fi® for fast network access. With one full-size HDMI port and RGB, you can easily expand your viewing area over two screens or present documents on an external display. There's also the convenience of an SD card slot and DVD Super Multi Drive. And with two USB 3.0 ports and one USB 2.0 port, you have all the flexibility you need to connect to office peripherals, right when you need them.
  • Long-lasting battery
    Busy execs can enjoy unplugged freedom to stay productive for long hours with the removable battery. Plus, Toshiba's battery lifecycle eco-charging mode increases charging cycles by up to 40%.
  • Keeps you productive
    With its rigid and robust chassis, the Satellite Pro R50 has a proven low failure rate. It stands up to the rigors of daily business use, reducing IT maintenance and significantly lowering downtime.
  • Built for business
    The Satellite Pro R50 is designed, engineered, manufactured and tested by Toshiba to help you succeed in business. Enjoy the peace of mind that this reliable professional notebook keeps your business moving forwards.
  • Smart, thin and light
    The stylish, sturdy Satellite Pro R50 makes an elegant portable office for busy execs on the go. The ergonomically designed chassis is easy to carry and use, measuring only 24 mm slim.
  • Proven reliability
    The R50 is built to handle the rough and tumbles of life in the office and on the road. Toshiba's Highly Accelerated Life Testing (HALT) includes drop, impact and spill tests to build in world-class reliability.
  • Portable with an odd
    Unlike many ultraportable, the Satellite Pro R50 features a built-in DVD SuperMulti Drive, capable of reading and writing the most popular disc formats.
Dynabook Toshiba Satellite Pro R50-B-123 - 15.6" - Intel Core i5 - 4210U - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 8.1 64-bit
Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4400
Input Device
ClickPad
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 6.42 hours
Black, tile black (keyboard)
37.9 cm x 25.8 cm x 2.395 cm
2.3 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4210U / 1.7 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Sound
Stereo speakers, microphone
High Definition Audio, DTS Sound
Input
Keyboard, ClickPad
Numeric Keypad
Multi-touch clickpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3160
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
45 Wh
Run Time
Up to 6.42 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
2 x USB 3.0 , LAN , VGA , Headphone/microphone combo jack , HDMI , USB 2.0
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Toshiba PC Health Monitor, Toshiba Eco Utility, EverNote, Toshiba Media Player, Toshiba Function Keys, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription), CyberLink MediaStory
Case Material
Polycarbonate ABS
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
Power adapter
Localization
2.3 kg
Sustainability Information
ENERGY STAR Certified
