The Satellite Pro C70 is the perfect option for businesses looking for a combination of quality and leading value. It features a textured design that prevents unwanted fingerprints on the lid, keyboard and palm-rest. Extensive connectivity options are incorporated and include SuperSpeed USB 3.0, HDMI and an integrated numeric keypad for added convenience and ease of use.
Well connected
Toshiba laptop is ready for business with extensive connectivity options featured as standard including HDMI and VGA connectivity with the USB ports. USB 3.0 is the USB standard that offers transfer rates faster than high speed USB 2.0. HDMI connectivity enables high definition connectivity from your laptop to AV equipment including your HD TV. -
Reliably efficient
With powerful processor and a fast HDD, the C70 delivers a consistently powerful performance, from boot-up to shut-down. -
Ideal for work
The widescreen C70 helps you complete your office tasks in comfort. You can expect incredible quality with no harsh glare from the non reflective backlight display and take advantage of its improved full-size keyboard with numeric keypad, for a faster way to key in figures.
- Dynabook Toshiba Satellite Pro C70-B-34U - 17.3" - Intel Core i5 - 5200U - 6 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 6 GB DDR3L (1 x 4 GB + 1 x 2 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- AMD Radeon R7 M260
- Video Memory
- 2 GB DDR3 VRAM
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell - up to 7 hours
- Matt black with textured pattern, black keyboard
- 41.3 cm x 26.8 cm x 3.37 cm
- 2.7 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 6 GB (1 x 4 GB + 1 x 2 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB DDR3 VRAM
- Video System Features
- AMD Enduro technology
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- High Definition Audio, DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3160
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 6-cell Lithium Ion
- Run Time
- Up to 7 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 3.42 A
Connections & Expansion
- 2 x USB 3.0 , LAN , VGA , Headphone output , HDMI , USB 2.0 , Microphone input
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Cyberlink PowerDVD, Toshiba PC Health Monitor, Toshiba Eco Utility, EverNote, Toshiba Media Player, Toshiba Function Keys, Toshiba System Settings, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription), CyberLink MediaStory
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, Toshiba EasyGuard, USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 2.7 kg
Sustainability Information
- ENERGY STAR Certified
