The Satellite Pro C70-B combines comprehensive connectivity and an elegant design in one highly affordable business laptop. Capture every detail with stunning clarity on a large, 43.9 cm (17.3") non-reflective HD+ screen with LED backlighting - and complete office tasks efficiently, thanks to the high-performance Intel Core processor and full-size keyboard with numeric keypad. With the C70-B, you're always ready for business.
A laptop designed for you
Whatever your business, there's a Satellite Pro C70-B just for you. With the speed and performance that meets your needs. Its all-round power, reliability and functionality, delivered at an affordable price. -
Get the job done
The Satellite Pro C70-B's impressive widescreen display and full-size keyboard with numeric keypad ensures you have the tools you need to complete every office task successfully. Enjoy incredible quality with no harsh glare from the non-reflective 43.9 cm (17.3") HD+ LED backlight display - and multi-task using various windows to make the most of the larger screen. -
Built for business
The Satellite Pro C70-B is the smarter choice for today's business professionals. Packed with specific features designed for a business environment, it brings higher speeds and efficient performance to the boardroom and the home office. And of course, it's as uncompromisingly reliable as you've come to expect from Toshiba. -
Works wherever you do
Enjoy flexibility beyond the office. The Satellite Pro C70-B is packed with convenient connectivity, including HDMI and RGB ports, plus 2 x USB 3.0, 1 x USB 2.0, and a handy SD Card slot. Transfer data directly to your external devices up to 10 times faster using USB 3.0.
- Dynabook Toshiba Satellite Pro C70-B-14Z - 17.3" - Intel Core i5 - 4210U - 6 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit
- Processor
- Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 6 GB DDR3L (1 x 4 GB + 1 x 2 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- AMD Radeon R7 M260
- Video Memory
- 2 GB DDR3 VRAM
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell - up to 6.17 hours
- Matt black with textured pattern, black keyboard
- 41.3 cm x 26.8 cm x 3.37 cm
- 2.7 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4210U / 1.7 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 6 GB (1 x 4 GB + 1 x 2 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB DDR3 VRAM
- Camera
- Sound
- Stereo speakers, microphone
- High Definition Audio, DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3160
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 6-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 6.17 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- 2 x USB 3.0 , LAN , VGA , Headphone output , HDMI , USB 2.0 , Microphone input
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, Toshiba PC Health Monitor, Toshiba Eco Utility, EverNote, Toshiba Media Player, Toshiba Function Keys, Toshiba System Settings, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription), CyberLink MediaStory
- Case Material
- Polycarbonate ABS
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 2.7 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 90%
