Every Satellite Pro C50-A comes with quality, reliability and value built in. Simply open it up and you're ready for business. The Intel processor delivers an impressive performance from the start. Plus there's a full set of ports for faster, easier connections to your network and other devices. With all-round functionality from a brand you can rely on, this affordable Satellite Pro is always ready to do business.
Built for your business
Whatever the size and nature of your business, there's a Satellite Pro C50-A for you. And because every C50-A configuration delivers a reliable performance at an affordable price, you get plenty of added value every time you use it. -
Smarter investment
With a proven reputation for business laptops, the Satellite Pro range is the professional's choice. And you can see why, when dedicated business features, higher speeds and an efficient performance come as standard. Add to that Toshiba quality you can count on, and the reasonably-priced C50-A becomes a really smart investment. -
Consistently reliable
You rely on your business laptop. So you need to know that it will perform, day after day. With the Intel processor and a fast HDD, the C50-A delivers a consistently powerful performance, from boot-up to shut-down. Optimus technology automatically activates an outstanding graphics performance when you need it most - and deactivates it when you don't to increase your battery life. -
Commercial comfort
If you're looking to combine comfort with productivity, then the C50-A has all the answers. You can expect amazing picture quality with no harsh glare from the non-reflective 39.6 cm (15.6") HD LED backlight display. And an improved full-size keyboard with a useful numeric keypad, for faster number-crunching.
- Dynabook Toshiba Satellite Pro C50-A-1KJ - 15.6" - Intel Core i5 - 4200M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit
- Processor
- Intel Core i5 (4th Gen) - 4200M / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4600
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- Up to 4.5 hours
- Matt black with hairline pattern, black keyboard
- 38 cm x 24.2 cm x 3.335 cm
- 2.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4200M / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM86
- Enhanced SpeedStep technology, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Max Allocated RAM Size
- 1792 MB
- Camera
- Resolution
- 0.9 Megapixel
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC269Q
- High Definition Audio, DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 4.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- 2 x USB 3.0 , LAN , VGA , Headphone output , HDMI , USB 2.0 , Microphone input
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, Windows 8.1 Pro 64-bit (DVD)
- Case Material
- Polycarbonate ABS
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.3 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 90%
