The 38.1 cm (15") Satellite Pro A50-C is designed to help professionals be more productive. From its premium components, to its solid build, you can depend on the laptop to provide support day in, day out - and we're so confident in its quality that every model comes with our Reliability Guarantee. This means in the unlikely event that your laptop breaks, we'll give you a full refund and a free repair* - so you'll be back up and running quickly, with minimum disruption. But that's not all. With the Satellite Pro A50-C, you're able to choose a configuration that best suits you and your needs. There are several combinations of powerful Intel® CoreTM processors, storage options, and display resolutions to select - making it easy to find your ideal business laptop. In fact, everything about the Satellite Pro A50-C has been developed with professionals in mind. The premium interior components deliver smooth performance and connectivity, while the
high-clarity non-glare screen and full-size keypad mean you can always work to your full potential - enabling you to be more productive, more of the time.
5th Generation Intel® Core™ i7-5500U Processor with Intel® Turbo Boost Technology 2.0 (2.40 / 3.00 Turbo GHz, 3rd level cache: 4MB)
Windows 8.1 64-bit (pre-installed) free upgrade to Windows 10
39.6cm (15.6") Toshiba TruBrite® Full HD TFT High Brightness IPS display with LED backlighting, 16 : 9 aspect ratio, internal resolution: 1,920 x 1,080
1 TB (5,400 rpm) SATA HDD
8GB DDR3L RAM (1,600 MHz)
Slim DVD Super Multi (Double Layer) drive
NVIDIA® GeForce® 930M with NVIDIA® Optimus™ Technology, 2GB dedicated VRAM
1 year European Carry-in warranty
Speed through multiple tasks
Busy professionals need to multi-task - and their business laptop needs to help them do it. With high-capacity processor, the Satellite Pro A50 lets you power through your workload with ease. So you can just focus on the tasks at hand, even when working with multiple applications or different documents at the same time, to get the job done. -
Faster response to every command
Your laptop shouldn't hold you back. When you want it to do something, you expect a quick reaction. And you can expect nothing less than the fastest response from the Satellite Pro A50. There's no time delay or waiting around. So as soon as you want to boot up, shut down, or open, save and store your files - you can.
- Dynabook Toshiba Satellite Pro A50-C-135 - 15.6" - Intel Core i7 - 5500U - 8 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit
- Processor
- Intel Core i7 (5th Gen) - 5500U / 2.4 GHz, up to 3 GHz / 4 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce 930M
- Video Memory
- 2 GB DDR3 VRAM
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 7 hours
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Graphite black, black (keyboard)
- 37.9 cm x 25.8 cm x 2.395 cm
- 2.2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Intel Core i7 (5th Gen) 5500U / 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- HighBrightness, TruBrite
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB DDR3 VRAM
- Video System Features
- NVIDIA Optimus
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Palm Rejection Technology, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 7 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- 2 x USB 3.0 , LAN , HDMI , Headphone/microphone combo jack , VGA , 2 x USB 2.0
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Cyberlink PowerDVD, Toshiba PC Health Monitor, Toshiba Eco Utility, EverNote, Toshiba Function Keys, Toshiba System Settings, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription), CyberLink Power Media Player 12
- Case Material
- Polycarbonate ABS
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, remote boot control
- Included Accessories
- Power adapter
- Localization
- 2.2 kg
Sustainability Information
- ENERGY STAR Certified
