The Toshiba 15.6" C50 Pentium Laptop
When you consider a laptop purchase it worth while to consider how well built tha laptop is and Toshiba have always been known for high quality. This build ethic is also backed up in this laptop with a powerful Intel Pentium 2020m 2.4 GHz processor and 6GB ram. When you add this to the massive amount of ways to connect including: Bluetooth, HDMI and USB3 then you really have a best in class machine in the mid-range category.
Well Connected
Toshiba laptops come with a range of features and connectivity options that enhance your user experience. The spacious full size keyboard with numeric keypad is ideal for applications such as spreadsheets, and ensures typing is comfortable. Swap pictures and files or expand your storage capabilities using the SD card slot, plug into the 1x USB 3.0 or 2x USB 2.0 ports to share content with your other devices. USB 3.0 is the latest USB standard that offers transfer rates up to 10 times faster than Hi-Speed USB 2.0. HDMI connectivity enables high definition connectivity from your laptop to AV equipment including your HD TV.
Streamlined Design
The Satellite C50 features a new streamlined design with a textured matt black finish and weighs from only 2.4kg. The textured finish helps to minimise fingerprint marks as well as giving a smart look and feel. The 39.6cm (15.6") display with LED backlighting delivers sharp and vivid images.
High Quality Audio
The integrated stereo speakers are positioned below the screen and combine with DTS Sound audio suite to ensure that music or movie soundtracks can be enjoyed at their best. DTS Sound includes a sound enrichment suite that boosts volume, enhances bass and improves definition. Enjoy immersive audio complete with deep, rich bass and crystal clear dialogue. DTS Sound also delivers high-frequency definition for crisp detail in any listening environment, ensuring users a premium and natural entertainment experience whether you are using the laptop speakers or headphones.
MAIN FEATURES
- Processor: Intel Pentium Dual Core 2020M (2.4GHz, 2MB Cache)
- Screen: 15.6" (Toshiba TruBrite TFT, 1366x768 WXGA resolution, LED Backlight)
- RAM 6GB: (DDR3)
- Hard Drive: 500GB
- Optical Drive: DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi)
- Graphics: Integrated (Intel HD Graphics)
- Wireless LAN: Wireless (802.11b/g/n Wireless)
- Network Card: 10/100/1000 Gigabit Fast Ethernet
- Features: WEBCAM , CARD READER (SD/SDHC,MMC) , BLUETOOTH 4.0
- Ports : 2x USB 2.0, 1x USB 3.0 , HDMI, VGA
- Speakers: Integrated Sound System
- OS: Win8
- Warranty: 12 Months
Built for your business
Whatever the size and nature of your business, there's a Satellite Pro C50-A for you. With the Pentium processor, you can create the ideal business laptop for your everyday needs. And because C50-A delivers a reliable performance at an affordable price, you get plenty of added value every time you use it. -
Smarter investment
With a proven reputation for business laptops, the Satellite Pro range is the professional's choice. And you can see why, when dedicated business features, higher speeds and an efficient performance come as standard. Add to that Toshiba quality you can count on, and the reasonably-priced C50-A becomes a really smart investment. -
Maximum flexibility
The C50-A is versatile, in and out the office. You have a choice of USB 2.0 and USB 3.0 ports to transfer data to your storage devices. And you can zip it there up to 10 times faster using USB 3.0. 802.11 b/g/n Wi-Fi gives you the added connection speed you need. With HDMI, you have the flexibility to share your work on display devices. And you get the wireless freedom to sync your mobile devices too, with Bluetooth 4.0 built in. -
Consistently reliable
You rely on your business laptop. So you need to know that it will perform, day after day. With the Intel Pentium processor and a fast 5400 rpm HDD, the C50-A delivers a consistently powerful performance, from boot-up to shut-down. -
Commercial comfort
If you're looking to combine comfort with productivity, then the C50-A has all the answers. You can expect amazing picture quality with no harsh glare from the non-reflective 39.6 cm (15.6") HD LED backlight display. And an improved full-size keyboard with a useful numeric keypad, for faster number-crunching.
- Dynabook Toshiba Satellite Pro C50-A-1HR - 15.6" - Intel Pentium 2020M - 6 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit
- Processor
- Intel Pentium 2020M / 2.4 GHz / 2 MB Cache
- Memory
- 6 GB DDR3 (1 x 4 GB + 1 x 2 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- Up to 3.5 hours
- Matt black with hairline pattern, black keyboard
- 38 cm x 24.2 cm x 3.335 cm
- 2.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- L3 - 2 MB
- 64-bit Computing
- Enhanced SpeedStep technology
- RAM
- 6 GB (1 x 4 GB + 1 x 2 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3 SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Max Allocated RAM Size
- 1981 MB
- Camera
- Resolution
- 0.9 Megapixel
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC269Q
- High Definition Audio, DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Wi-Fi CERTIFIED
- Technology
- Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 3.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- USB 3.0 , LAN , VGA , Headphone output , HDMI , 2 x USB 2.0 , Microphone input
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Toshiba Media Player, Toshiba Function Keys, Toshiba Desktop Assist, Toshiba System Settings, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription)
- Case Material
- Polycarbonate ABS
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.3 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 90%
