Feature Rich & Value Packed
The Satellite C50 series offers great value and great quality for everyday computing and features a 39.6cm (15.6") display and textured matt black finish. Extensive connectivity options are incorporated and include SuperSpeed USB 3.0, HDMI and integrated numeric keypad for added convenience and ease of use.
Mani features
- Processor: IntelĀ® CeleronĀ® 1005M processor clock speed : 1.90 GHz 3rd level cache : 2 MB
- Display: (15.6") with 16 : 9 aspect ratio and LED backlighting and l resolution : 1,366 x 768
- RAM: 4GB installed
- Hard disk 500 GB
- Interfaces: USB 2 & 3, Card reader, HDMI , VGA, WEBCAM, Bluetooth
- Wired : Fast Ethernet LAN speed : 10BASE-T/100BASE-TX
- Wireeless: 802.11a/b/g/n (up to 300Mbps)
- OS Windows 8.1 64-bit (pre-installed)
- Warranty 1 Year
Built for your business
Whatever the size and nature of your business, there's a Satellite Pro C50-A for you. And because every C50-A configuration delivers a reliable performance at an affordable price, you get plenty of added value every time you use it. -
Smarter investment
With a proven reputation for business laptops, the Satellite Pro range is the professional's choice. And you can see why, when dedicated business features, higher speeds and an efficient performance come as standard. Add to that Toshiba quality you can count on, and the reasonably-priced C50-A becomes a really smart investment. -
Consistently reliable
You rely on your business laptop. So you need to know that it will perform, day after day. With the Intel processor and a fast HDD, the C50-A delivers a consistently powerful performance, from boot-up to shut-down. Optimus technology automatically activates an outstanding graphics performance when you need it most - and deactivates it when you don't to increase your battery life. -
Commercial comfort
If you're looking to combine comfort with productivity, then the C50-A has all the answers. You can expect amazing picture quality with no harsh glare from the non-reflective 39.6 cm (15.6") HD LED backlight display. And an improved full-size keyboard with a useful numeric keypad, for faster number-crunching.
- Dynabook Toshiba Satellite Pro C50-A-1MM - 15.6" - Intel Celeron - 1005M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 8.1 64-bit
- Processor
- Intel Celeron 1005M / 1.9 GHz / 2 MB Cache
- Memory
- 4 GB DDR3 (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- Up to 3.5 hours
- Matt black with hairline pattern, black keyboard
- 38 cm x 24.2 cm x 3.335 cm
- 2.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- L3 - 2 MB
- 64-bit Computing
- Enhanced SpeedStep technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3 SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Max Allocated RAM Size
- 1739 MB
- Camera
- Resolution
- 0.9 Megapixel
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC269Q-VB5-GR
- High Definition Audio, DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Wi-Fi CERTIFIED
- Technology
- Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 3.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- USB 3.0 , LAN , VGA , Headphone output , HDMI , 2 x USB 2.0 , Microphone input
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Toshiba Media Player, Toshiba Function Keys, Toshiba Desktop Assist, Toshiba System Settings, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription)
- Case Material
- Polycarbonate ABS
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
- Included Accessories
- Power adapter
- Localization
- 2.3 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 90%
