The AT300 features the eagerly awaited Android 4.0 operating system and the nVidia Tegra T30SL quad core processor. With a 10.1" Gorilla glass display, the AT300 weighs in at a mere 598grams and even with its ultra thin profile of 8.6mm, it is packed with connectivity including Full Size SD, Micro-HDMI and Micro-USB - making transfer and viewing of content a breeze. It is further enhanced by Google Play with over 500,000 apps.
Stunning ultra thin design
The Toshiba AT300 combines extensive features with an unbelievably slim and lightweight design, measuring just 8.6mm and weighing a mere 598 grams. The elegant and solid brushed-metal design sits comfortably in the hand, making it ideal to use on the move or around your home. -
Extensive connectivity
Swap pictures and files or expand your storage capabilities using the full-size SD card slot, plug into the micro-USB port to share content with your other devices and use the micro-HDMI port to connect to your TV. -
nVIDIA Tegra
An nVIDIA Tegra T30SL processor enables amazing multitasking, web surfing, gaming and video. It features a 4-PLUS-1 mobile quad-core CPU, so you get amazing performance and it has a unique fifth battery-saver core for a longer battery life. The nVIDIA Tegra T30SL processor uses this low-power core to handle everyday apps, and then full quad-core mode for demanding apps. -
Android 4.0
The Android 4.0 platform is optimized for Tablet devices and delivers a simple holographic UI design, five customisable Home screens, plus access to Google Play where you can choose from over 500,000 apps as well as a full suite of popular Google Mobile services including YouTube, Gmail, Google Maps and more. -
Touchscreen display
The 25.7cm (10.1'‘) HD capacitive touchscreen display provides exceptional 1280x800 resolution with wide viewing angles and precision control, whilst the exclusive adaptive display technology adjusts brightness and contrast to the surrounding light conditions. Gorilla Glass ensures that the display is highly resistant to damage from scratches and the anti-fingerprint coating reduces fingerprints and is easy to clean. Sound enhancement software and the built-in stereo speakers ensure high quality sound.
- Toshiba AT300-105 - tablet - Android 4.0 - 16 GB - 10.1"
- Product Type
- Tablet
- Operating System
- Android 4.0
- Display
- 10.1" TFT - LED backlight - 1280 x 800
- Processor
- NVIDIA Tegra 3 (Quad-Core)
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB
- RAM
- 1 GB
- Supported Flash Memory Cards
- SD Memory Card, MultiMediaCard, SDHC Memory Card
- Wireless Connectivity
- 802.11n, Bluetooth 3.0
- Rear Camera
- 5 Megapixel focus: automatic
- Front Camera
- 2 Megapixel
- USB host, HDMI Port
- Battery Run Time
- Up to 12 hours
- 17.89 cm x 0.895 cm x 26.06 cm
- 595 g
- Silver aluminium with textured pattern
- Localisation
- United Kingdom
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Android 4.0
Display
- Resolution
- 1280 x 800
- TruBrite, Corning Gorilla glass, scratch-resistant
- Processor
- NVIDIA Tegra 3
- 1.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 16 GB
- RAM
- 1 GB - DDR3L SDRAM
- Max Supported Capacity
- 32 GB
Communications
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
Front Camera
- Sensor Resolution
- 2 Megapixel
Multimedia
- Audio
- Microphone, stereo speakers
Software
- Preloaded Software
- Twitter, Printer Share, Toshiba Media Player, Toshiba File Manager, McAfee WaveSecure, Evernote, Toshiba Places Client, Splashtop, Toshiba Video Enhancement, Toshiba Audio Enhancement, ThinkFree, Skitch, Adobe Reader
Expansion and Connectivity
- Expansion Slots
- 1 x SDHC Memory Card
- 1 x Micro-USB , 1 x Micro-HDMI , 1 x headset , 1 x dock
- USB Host
- HDMI Port
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Technology
- Lithium polymer
- Capacity
- 25 Wh
- Run Time
- Up to 12 hours
- Run Time Details
- Video playback: up to 10 hour(s) , Audio playback: up to 36 hour(s)
- Volume control
- Included Accessories
- Power adapter
- Localisation
- United Kingdom
- 17.89 cm
- 0.895 cm
- 26.06 cm
- 595 g
- EMEA warranty - 1 year
- 5 °C
- 40 °C
- 20 - 85%
- Min Storage Temperature
- -30 °C
- Max Storage Temperature
- 60 °C
- Max Altitude Operating
- 3 km
