STOR.E PARTNER is a stylish external drive for storing your data! Subtle metallic reflections and engraved dots accent its fresh look in a robust, rubber-textured casing. Transfer media files in a snap from your laptop via SuperSpeed USB 3.0. The STOR.E PARTNER drive is large enough to house huge digital media libraries.
Key Features*
- Transfers your large media files at SuperSpeed (up to 5.0 Gbps) with USB 3
- Backwards compatible with USB 2.0
- Robust casing with engraved dots and rubber texture
- Plug'n'Play
- Pre-loaded Nero BackItUp & Burn Essentials
The Perfect Partner
- Style: The design of Toshiba's STOR.E PARTNER perfectly matches the Toshiba NB500 netbook series' young and fresh looks with subtle metallic reflections, engraved dots and rubber texture.
- High Capacity for Large Media Libraries: The storage capacity of the external hard disk drives of up to 1TB is large enough to house huge digital media libraries. Via its USB 3.0 port, STOR.E PARTNER transfers large media files quickly to connected USB 3.0 laptop.
- Back Up Sofrware on-board: The pre-loaded Nero BackItUp & Burn Essentials software comfortably and reliably backs up and restores files and folders and recovers damaged or accidentally deleted data.
- Toshiba StorE PARTNER - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Ramp Load
- Power Source
- USB bus
- Enclosure Colour
- Black
- 8.3 cm x 11.9 cm x 1.4 cm
- 160 g
- Designed For
- Dynabook Toshiba Portégé R930, Z830, Z930; Toshiba Satellite Pro C660, C850, L770, L870; Toshiba LX830; Qosmio F750, X770, X870; Satellite C660, C850, C850D, C855, C855D, C870, C870D, C875D, L735, L750, L755D, L775, L775D, L830, L850, L855, L855D, L875D, L955D, P750, P845t, P850, P870, P875, R830, R930, U840, U940, Z830, Z930
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Ramp Load
- 8.3 cm
- 11.9 cm
- 1.4 cm
- 160 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Software Included
- Nero BackItUp & Burn Essentials
- OS Required
- Microsoft Windows 7
- Cables Included
- 1 x USB 3.0 cable - external
- Plug and Play
- Enclosure Colour
- Black
- Designed For
- Dynabook Toshiba Portégé R930-109, R930-10J, R930-115, R930-116, R930-117, R930-12Q, R930-13U, R930-14T, R930-14X, R930-14Z, R930-151, R930-152, R930-153, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV, Z830-12D, Z930-10M, Z930-10P, Z930-10Q, Z930-11C, Z930-11G, Z930-12G, Z930-12H, Z930-137, Z930-138, Z930-13L, Z930-13M, Z930-146, Z930-147, Z930-14D, Z930-153 , Dynabook Toshiba Satellite Pro C660-2MV, C660-2MW, C660-2QC, C660-2QD, C660-2UK, C850-14K, C850-157, C850-158, C850-19G, C850-1CV, C850-1D4, C850-1DC, C850-1DE, C850-1K1, C850-1K2, L770-15T, L870-14E, L870-16Z, L870-179, L870-18G, L870-18L , Toshiba LX830-11G , Toshiba Qosmio F750-125, X770-120, X770-124, X770-137, X770-138, X770-13H, X870-11P, X870-13U, X870-13Z, X870-140, X870-141, X870-142, X870-149, X870-15K , Toshiba Satellite C660-2PP, C850-16W, C850-1C8, C850-1DV, C850-1DW, C850-1M8, C850D-105, C850D-11F, C850D-121, C855-1TH, C855-1TJ, C855-1U8, C855-1VU, C855-1XH, C855-25L, C855D-12P, C855D-13J, C855D-149, C855D-14C, C870-15E, C870-17L, C870-17T, C870-17U, C870-1HE, C870D-109, C870D-10C, C870D-10M, C870D-10X, C875D-10E, L735-158, L750-22C, L755D-13D, L755D-14H, L755D-14N, L755D-14X, L775-139, L775-17T, L775D-10F, L775D-10Q, L775D-10R, L830-13J, L850-1FF, L850-1G7, L850-1K8, L855-14W, L855D-104, L855D-10G, L855D-10H, L875D-104, L875D-106, L955D-107, P750-141, P845t-103, P845t-104, P850-30Q, P850-30W, P850-31W, P850-31X, P850-31Z, P850-320, P850-32D, P850-32M, P870-308, P870-30D, P870-31E, P870-31G, P870-31Z, P870-320, P870-32F, P875-30G, P875-30K, P875-31J, P875-31R, P875-327, P875-32F, P875-32G, R830-1CN, R830-1JR, R830-1JU, R930-16W, R930-1CV, U840-10T, U940-101, U940-104, Z830-10M, Z830-11H, Z930-13C
