Get down to business with the Tecra R950. It's the perfect 15.6" laptop for businesses demanding long-lasting performance. Built to last, it delivers up to long battery life for a full day out of the office and is extremely thin and light with excellent design using high-strength composite materials. The non-reflective screen and dedicated docking make it a comfortable and versatile companion. Featuring the powerful technologies for built-in manageability and security, it is ideal for fleet deployment.
Lasts longer
The R950 is designed to go long distances. High-stiffness resin casing combined with an innovative inbuilt honeycomb structure, a spill-resistant keyboard and advanced Toshiba business features, help to protect the laptop and its data from shocks and drops. And you won't miss any office comforts thanks to the 15.6" non-reflective screen with LED backlighting and a spill-resistant keyboard with full-size format and separate numeric keypad. -
Great connections
This laptop features USB 2.0 and USB 3.0 ports for fast data transfer. USB sleep-and-charge lets you recharge your mobile devices without switching the computer on. If you need to transfer large files over your network quickly, then you'll love the built-in Gigabit LAN adapter. There's an internal slot for Bluetooth means you can sync your mobile devices without a cable and make video calls using a wireless headset. The DisplayPort connection gives you maximum flexibility when connecting to display devices. And for quick, easy connection to your entire office environment, there's the dedicated docking station port. -
Reliable and secure for lower costs
High stiffness resin casing combined with the innovative inbuilt honeycomb structure, durable hinges, a spill-resistant keyboard, and Toshiba's advanced HDD shock protection, help protect the laptop and its data from shocks and drops. -
Well-managed workforce
The R950 makes it easy to manage a mobile workforce. For added security, there's a fingerprint reader and Trusted Platform Module for high-level data encryption. That's the IT department can keep you running safely and up-to-date even when away from the office. -
Eco friendly
The R950 features efficient, state-of-the-art power management and is ENERGY STAR qualified.
- Dynabook Toshiba Tecra R950-153 - 15.6" - Intel Core i5 3320M - vPro - 4 GB RAM - 320 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (3rd Gen) 3320M / 2.6 GHz (3.3 GHz) / 3 MB Cache
- Memory
- 4 GB DDR3 (1 x 4 GB)
- Storage
- 320 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4000
- Input Device
- AccuPoint
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell - up to 10 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- Graphite black with grooved texture, matte black keyboard
- 37.9 cm x 25.2 cm x 2.54 cm
- 2.49 kg
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- International warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel QM77 Express
- Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 320 GB HDD SATA 3Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Max Allocated RAM Size
- 1696 MB
- Camera
- Resolution
- 1 Megapixel
- Video Resolutions
- 1280 x 800
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC269Q
- High Definition Audio, SRS Premium Sound HD
Input
- Keyboard, touchpad, AccuPoint
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Centrino Advanced-N 6235
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel 82579LM
- Wi-Fi CERTIFIED
- Technology
- 6-cell Lithium Ion
- Capacity
- 66 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- VGA , LAN , Headphone/microphone combo jack , USB 2.0/eSATA , DisplayPort , USB 2.0 , 2 x USB 3.0 , Dock
- Memory Card Reader
- Yes (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card, SDHC Card)
Software
- Software Included
- Toshiba TEMPRO Performance Tuning Service, McAfee Internet Security Suite (30 days subscription), Skype, Infineon TPM Professional Package, Toshiba Assist, Toshiba PC Health Monitor, Toshiba Recovery Media Creator, Toshiba Eco Utility, Toshiba Security Assist, Toshiba HDD Protection, Toshiba Service Station, Microsoft Office 2010 Starter, Toshiba HDD/SSD Alert, Nero Kwik Media, Nero BackItUp & Burn Autobackup, Toshiba Intelligent Display Management, Windows 8 Pro 64-bit recovery DVD
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Intel Anti-Theft Technology (iAT), Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 2.49 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
