the Thermaltake TR2 Challenger Series is the latest PSU with the 80 Plus Standard certification and available in 500W, 600W and 700W versions.TR2 Challenger 500W proves most reliable and robust power delivery, by using high quality components. The ultra-quiet 120mm cooling fan ensure excellent airflow. Simply the best combination of features, performance and quality in the category of a popular price ratio.Connections
1x 24-pin Motherboard Connector
1x 4+4-pin 12V Connector
1x 4-pin Connector
1x 6+2-pin PCI-E Connector
3x 4-Pin Molex Connectors
6x SATA Connectors
1x Floppy Connector
Operating Humidity: 20% to 90%, non-condensing
Storage Temperature: -20 Ž to +70 Ž
Storage Humidity: 5% to 95%, non-condensing
Detailed Information
Dimensions: 150mm x 86mm x 140mm (W x H x D)
Input Voltage: 200Vac~230Vac
Input Current: 4.0A max
Input Frequency Range: 47Hz-63Hz
PFC: Active PFC
Power Good Signal: 100-500 ms
Hold Up Time: 10msec (minimum) within 80% load at 230Vac input
Efficiency: 82-86%
MTBF: 100,000 hrs minimum
Protection: OVP
Power: 500W
Operation Temperature: 0 Ž to +40 Ž
Safety: CE/CB/TUV
Cooling: 12cm fan, 1500 R.P.M. }10%
Noise: 31.8
80 Plus Certified: Yes - 80 Plus
Certification: nVidia SLi Certified, ATi Crossfire Certified
*General Specifications *
Manufacturer Part Number: TTP-0500P
EAN Number: 4717964401106
Has Mains Plug: No
Colour: Black
What's In The Box: 1x TTP-0500P PSU
Unit (Product) Dimensions (mm): 150mm x 86mm x 140mm (W x H x D)
Net Weight (KGs): 1.65 KGs
Gross Weight (KGs): 17 KGs
Main Features:
Ultra Quiet Fan - Ultra-quiet 120mm cooling fan delivers excellent airflow at an exceptionally low noise level
80 PLUS Standard Certified and Haswell Ready - TR2 Challenger series is prepared for the new Intel processors Haswell to achieve maximum energy savings
Massive and Dedicated Single +12V Output - High-Quality components and single +12V rails design enable non-stop usage with stable and reliable performance
Heavy-duty protection circuitry - Over Voltage, Over Power and Short-Circuit protections
Safety / EMI Approvals - CE/CB/TUV
High quality 105°C Japanese electrolytic capacitor
105°C Japanese main capacitor provides uncompromised performance and reliability. -
Industrial grade protection
Built in industrial-grade protections: over current, over voltage, under voltage, over power and short-circuit protections. -
Ultra quiet 12cm fan
TR2 series adopt 12cm cooling fan with intelligent RPM control guarantees cool performance and silent operation. -
High efficiency circuit design
Maximum efficiency is up to 88% under wide load range. -
80 Plus bronze certified
TR2 series saves energy through its high energy efficiency of up to 88% and is 80 Plus Bronze certified. -
Supports Energy Star 5.0 energy standard:
TR2 series is suitable for use in Energy Star-compatible computers. -
Corresponds to the EU directives on WEEE and RoHS
Thermaltake considers its full impact on the environment during manufacturing and maintains green facilities to ensure TR2 meets WEEE and RoHS requirements.
